Air Electric Breakdown: Understanding Voltage/Distance Limits
  • Context: Undergrad
  • Thread starter Thread starter ctech4285
    Air Electric Limits
The discussion centers on the concept of electric breakdown in air, specifically noting that a conducting sphere with a radius of 1 meter cannot exceed a voltage of 3 MV due to the dielectric strength of air. The electric field strength, defined as approximately 3 x 106 V/m, is the critical factor for breakdown, rather than the physical size of the object. Gauss' law is utilized to derive the electric field and potential equations, illustrating that the electric field strength decreases with distance from the charge. This understanding is essential for applications involving high-voltage systems and electrical discharges.
  • Understanding of Gauss' Law in electromagnetism
  • Familiarity with electric field strength and potential difference concepts
  • Knowledge of dielectric materials and their breakdown characteristics
  • Basic principles of electrostatics and charge distribution
  • Study the applications of Gauss' Law in various geometries
  • Research the dielectric strength of different gases and materials
  • Explore the phenomenon of electrical discharge and its applications in technology
  • Investigate the effects of high-voltage systems on surrounding environments
Electrical engineers, physicists, and anyone involved in high-voltage applications or studying electrical phenomena will benefit from this discussion.
ctech4285
i been watching some lectures from OCW and the professor said something like a ball with a radius of 1m can not exceed 3MV because of the electric breakdown of air.
to me it sounds like you can not exceed a potential difference 3MV per meter. so it does not matter the physical size of an object just the voltage difference over a distance is less.
It is the strength of the electric field, not the potential of the ball that determines when the air breaks down.
You can use Gauss' law to determine the electric field:
[tex]\int E\cdot dA = \frac{q}{\epsilon_0}[/tex]
[tex]E = \frac{q}{4\pi r^2\epsilon_0}[/tex]
The electric potential outside the sphere is the same as if you were dealing with a point charge:
[tex]V = \frac{q}{4\pi r\epsilon_0}[/tex]
which means that E = V/r
So you can see that for a given voltage of a conducting sphere, the field strength varies as 1/r.
AM
http://en.wikipedia.org/wiki/Electrical_breakdown
Electrical breakdown occurs within a gas (or mixture of gases, such as air) when the dielectric strength of the gas(es) is exceeded. Regions of high electrical stress can cause nearby gas to partially ionize and begin conducting. This is done deliberately in low pressure discharges such as in fluorescent lights (see also Electrostatic Discharge) or in an electrostatic precipitator.
Partial electrical breakdown of the air causes the "fresh air" smell of ozone during thunderstorms or around high-voltage equipment. Although air is normally an excellent insulator, when stressed by a sufficiently high voltage (an electric field strength of about 3 x 106V/m[1]), air can begin to break down, becoming partially conductive. If the voltage is sufficiently high, complete electrical breakdown of the air will culminate in an electrical spark or arc that bridges the entire gap. While the small sparks generated by static electricity may barely be audible, larger sparks are often accompanied by a loud snap or bang. Lightning is an example of an immense spark that can be many miles long. The color of the spark depends upon the gases that make up the gaseous media.
