Thread Closed
transformer ? and current
Share Thread Thread Tools
Mar22-10, 07:17 PM   #1
like in a car when electrons flow through the battery to the coil , the coil is like a transformer using coiled copper wire to up the voltage to give the spark plugs a hotter spark. I am not sure where this energy is coming from , so are we actually getting more electrons to flow per second and after it goes through the coil . does the coil allow it to draw more current from the battery.
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Mar23-10, 04:17 AM   #2
Lok
Basically, all that matters is that total energy is conserved so energy per secons is :
P=U*I so P is a constant in a transformer ( at least consider it so)
If so then IF p=5W there are an infinity of possibilities for U and I. Like U=5 I =1 or I=5 U=1 etc.
That is what happens in a transformer, energy is the same it is just expressed differently.
For different ways transformers can be made consult wikipedia.
I"ve made the exemple in direct current for easy understanding :P
Mar23-10, 05:33 AM   #3
Mentor
Quote by cragar View Post
You have the wrong idea about what a transformer does: A transformer keeps the energy constant while increasing the voltage, which means fewer electrons per second going through the secondary side than the primary side.
Mar23-10, 11:40 AM   #4
i see thanks for your answers
Thread Closed
Thread Tools
Similar Threads for: transformer ? and current
Thread Forum Replies
Current Transformer Sizing Electrical Engineering 8
Sizing of Current transformer Electrical Engineering 0
Current transformer magnetics Electrical Engineering 51
Transformer Current Electrical Engineering 1
Current Sensing Transformer Electrical Engineering 2
