Calculating Acceleration on a Parabolic Curve
The discussion revolves around calculating the acceleration of a bead sliding along a parabolic wire described by the equation y=ax². The bead starts at the origin with an initial velocity Vo, and participants are exploring how to determine the acceleration at this point.
  • Mixed
  • Participants discuss the concept of radius of curvature and its relevance to the problem. Some suggest using the formula for radius of curvature, while others question whether additional information is needed to determine acceleration. There is also a focus on the relationship between velocity and acceleration on a curve.
Multiple approaches are being explored, including the use of curvature and the definition of acceleration as the second derivative of displacement. Some participants have provided mathematical expressions and derivations, while others are questioning the assumptions made regarding the motion of the bead.
There is an assumption that the bead slides with constant speed, which is being debated. The discussion also highlights the need for clarity on the relationship between velocity and acceleration in the context of the parabolic path.
dibilo
a smooth wire is shaped in the form of a parabola y=ax^2 on a horizontal plane. a bead slides along the wire. as it passes the origin, velocity is Vo. what is the acceleration.
i see the parabola as part of a big circle and decided to use a=v^2/r and i know s=r(theta)... then i am lost... help! :cry:
Sounds like you need to know r, which is the radius of curvature of the parabola at the origin.
(...looks up radius of curvature...)
Here it is:
[tex]R=\frac{[1+\left(\frac{dy}{dx}\right)^2]^{3/2}}{\frac{d^2y}{dx^2}}[/tex]
This is interesting. Would you show us how to derive this radius of curvature?
But just knowing the velocity at one point tells you nothing about the acceleration, on a curve or straight line. Is there more information?
We can assume that the bead slides on the horizontal wire with constant speed. Otherwise the problem would be undetermined. The acceleration can be calculated without knowing about curvature, just from its definition: that it is the second derivative of the displacement, that is the componts of the acceleration are the second derivatives of the coordinates with respect to time. Choosing the plane of motion as the (x,y) plane, the components of the velocity are
[tex]v_x=\dot x[/tex],
[tex]v_y= \dot y = 2ax \dot x =2axv_x[/tex].
The components of the acceleration are the derivatives of those of the velocity,
[tex]a_x= \dot v_x[/tex],
[tex]a_y=\dot v_y=2a\dot xv_x+2ax\dot v_y = 2a\left({v_x}^2+x\dot v_x\right)[/tex]
Moreover,
[tex]v_x^2+v_y^2=const \rightarrow v_x \dot v_x + v_y\dot v_y = 0[/tex]
The acceleration is asked at the origin, x=0, y=0. Here
[tex]v_y=0\mbox{, so } v_x^2=v_0^2[/tex].
Because of [tex]v_y=0[/tex] at x=0, the acceleration in x direction is also 0: [tex]\dot v_x=0[/tex].
(The tangent of the curve at x=0 is the x axis, and the tangential acceleration is zero when the speed is constant)
The result is :
[tex]a_x=0[/tex].
[tex]a_y=2av_0^2[/tex], the nagnitude of the acceleration is
[tex]2av_0^2[/tex].
ehild
thx for all the replies ... today my teacher gave me another way of solving this prob.
s=r[tex]\theta[/tex]=2x (whereby x is the 2 points [tex]\theta[/tex] cuts at the x-axis)
a=v^2/r
y=ax^2
[tex]\theta[/tex]/2= tan[tex]\theta[/tex]/2= dy/dx= 2ax
therefore [tex]\theta[/tex]=4ax
sub [tex]\theta[/tex]=4ax into s=r[tex]\theta[/tex]
r=1/(2a)
a=2av^2
  • · Replies 28 ·
  • · Replies 24 ·
