Calculating Force on a Ramp Using GPE: Clive's Question
  • Context: Undergrad
  • Thread starter Thread starter elvinc
    Force Gpe Ramp
The discussion centers on calculating the force required to pull a block weighing 10N up a smooth ramp with a vertical height of 1 meter and a sloping distance of 5 meters. The gravitational potential energy (GPE) gained by the block is 10J, which is derived from the work done against gravity. The force required to pull the block along the ramp is calculated as 2N by dividing the GPE by the distance moved along the ramp. A suggestion is made to use the formula F = mg sinθ to calculate the force parallel to the ramp, ensuring a more accurate assessment of the work done against gravity.
  • Understanding of gravitational potential energy (GPE)
  • Basic knowledge of forces and motion
  • Familiarity with trigonometric functions, specifically sine
  • Concept of work done against gravity
  • Learn how to apply the formula F = mg sinθ in various scenarios
  • Study the relationship between work done and gravitational potential energy
  • Explore the concept of frictionless surfaces in physics problems
  • Investigate the principles of inclined planes and their applications
Students studying physics, educators teaching mechanics, and anyone interested in understanding forces on inclined planes and gravitational potential energy calculations.
elvinc
Hi,
I'm not quite getting this.
Say we lift a block of weight 10N through a vertical height of 1 metre. So the work done is 10 x 1 = 10J. This 10J equals the g.p.e. Of the block.
Now we pull the block up the same height of 1 metre but along a smooth, straight ramp (no friction between block and ramp surface) for a sloping distance 5 metres. The force is acting parallel to the surface of the ramp.
At the end of the pulling up the ramp the block still has a g.p.e. of 10J. So we can work out the force required to pull the block = g.p.e gained / horizontal distance moved = 10 / 5 = 2N
But I feel I am cutting fast and loose to use the g.p.e which is gained by vertical motion to calculate a force in a horizontal (or at least sloping) direction. It just doesn't feel valid to me. What am I missing? Sorry question is a bit vague but that reflects my view on this.
Thanks
Clive
Try calculating the force required parallel to the ramp to just overcome gravity: F = mg sinθ
Use that to figure out the work done and compare that to the increase in gravitational potential energy.
