Moving electrical charges and Maxwell's equations
The discussion centers around the behavior of electrical charges, particularly electrons, in relation to Maxwell's equations. Participants explore whether a charge moving at constant velocity can be considered as an electromagnetic wave, the conditions under which radiation occurs, and the implications of acceleration on electromagnetic phenomena. The scope includes theoretical considerations and conceptual clarifications regarding electromagnetic radiation and wave behavior.
  • Some participants propose that an electron traveling with constant velocity does not radiate as an electromagnetic wave, as radiation requires acceleration.
  • Others argue that while constant velocity does not produce electromagnetic waves, accelerating charges create changing electric and magnetic fields that lead to radiation.
  • A later reply questions whether acceleration must always be oscillatory, suggesting that straight-line acceleration might still produce radiation.
  • Some participants discuss that oscillating charges create steady waves with fixed frequencies, while straight-line acceleration results in transient pulses with a broad spectrum.
  • There is a claim that constant acceleration produces a constant radiation field, although this is contested regarding its implications over large distances.
  • One participant notes that electrons exhibit wave behavior, such as diffraction, even when traveling at constant velocity, raising questions about the nature of these waves.
Participants generally agree that radiation requires acceleration, but there is disagreement about the nature of radiation produced by different types of acceleration and whether constant velocity charges exhibit wave behavior. The discussion remains unresolved regarding the implications of these points.
Limitations include the dependence on definitions of radiation and waves, as well as the unresolved nature of how constant velocity charges relate to wave behavior in quantum mechanics.
closet mathemetician
I'm confused about Maxwell's Equations.
1) does an electrical charge (say, an electron) traveling with a constant velocity (say, in the x-direction) travel as an electromagnetic wave?
I'm thinking of an analogy with flowing mass. Suppose you have massive particles, evenly distributed through some volume, traveling with constant velocity, say the x-direction. The flux across the (y,z) surface of a volume is calculated as the integral of the current density, vector [tex]\vec{J}[/tex] over the (y,z) surface area.
where
[tex]\vec{J}=\rho\cdot\vec{v}[/tex]
and
[tex]\int\int_A\vec{J}\cdot dA[/tex]
The result is the flow of mass across the (y,z) surface area per unit time, with units of kg/s. There is no curl in this vector field.
Now, imagine that instead of flowing mass, we have flowing electric charge in the x-direction across the (y,z) surface of a volume. Assume the electrons are not being accelerated as they flow across the (y,z) surface.
With this substitution the flux of mass across the surface becomes the flux of electrons across the surface with units of q/s, which is electrical current.
Does each electron rotatate as it travels in a straight line, producing an "infintesimal" rotation, which, when integrated over the surface area (y,z), produces an overall rotation of the vector field (Stokes theorem).
Does any of this cause the electrons to radiate? I don't see any light radiating when current travels through a metal wire.
Maybe I'm confusing electromagnetic waves traveling along the electric field lines with electrons traveling through space.
MY knowledge (which still remains untested) is that an accelerating electric charge produces a changing electric field. This changing electric field then produces a changing magnetic field which again sets up a changing electric field. This continuous process is known as an electromagnetic wave. Thus electromagnetic wave is actually caused by oscillations of electric and magnetic fields which arise due to an accelerating charge not a charge moving with constant velocity.
A charge moving with constant velocity only creates a constant magnetic field.
The simple answer is no. If a particle is moving at a constant (non-zero) velocity, that means there exists an inertial frame in which the particle has velocity of zero. Clearly there would be no EM waves in this frame since you simply have E = kq/r^2 (EM waves cannot be "gotten rid of" in this way). The other way to know it is not a EM wave is that EM waves travel at the speed of light (in free space). However, this "wave" simply travels at the speed of the particle.
As a side note, if you know electric field in this "rest frame", then you can perform a certain type of transformation (called a Lorentz transformation) to know the electric and magnetic fields in the original frame.
Thanks for the responses. I guess the key is that to radiate the charge must be accelerating, but must the acceleration always be in the form of an oscillation? What if you accelerated a charge in a straight line? Or, maybe if you tried that the charge would always oscillate anyway?Maybe what you are saying is that the very occurrence of the mutual induction of E and B fields causes the oscillation, so any time you accelerate a charge it will oscillate?
And yes, kcdodd, I know about Lorentz transformations (got lots of questions about that too, but I'll save for another thread).
... key is that to radiate the charge must be accelerating, but must the acceleration always be in the form of an oscillation? What if you accelerated a charge in a straight line? Or, maybe if you tried that the charge would always oscillate anyway?
An oscillating charge will create a steady wave with a fixed frequency. The oscillation can be charge flowing around a loop, or a straight line back and forth motion.
A straight line accelleration in one direction still creates radiation, but the wave is a transient pulse with a broad spectrum.
If I get too technical just tell me. The definition of radiation has to do with integrating the flux of power, or pointing vector (S = ExB), over a closed surface around the particle. For a single particle, the flux across this surface is proportional to the acceleration of the particle. Contrary to the last post, a constant acceleration will create a constant radiation field in a direction perpendicular to the path of travel. Clearly it also has no period, but it is clearly not a burst.
In fact, a particle which is rotating is the one which gives bursts of radiation (which, at least at one time, was the explanation for pulsars). Since the perpendicular direction to the path also rotates (except along the axis of rotation), you get an outward spiral of radiation. You actually call the "bursts" as waves, but depending on the exact parameters they may not look like waves (aka, broad spectrum of waves as the poster mentioned). So in short, radiation is not necessarily the same thing as waves.
you're good, kcdodd, I'm getting it, little, by little.
So, according to you, a charge accellerates by you and continues traveling on out to an infinite distance. When the the charge is 100 million light years away, you will still be experiencing a constant radiation field. Also, you will be seeing photons with infinite frequency (implying infinite energy) since you say they have no period (I assume no period means 0 period, hence f=1/T=infinity).
I didn't say rotating, I said traveling in a loop. A charge traveling in a circle can be viewed as a sinusoidal oscillation in both the x and y directions. Photons are generated at the frequency of the charge circulation (cyclic frequency). If the angular velocity is constant and this exists for a long time, then you have a steady state solution, which is what I mean by a steady wave with fixed frequency.
By no period, I mean it is not periodic. And I also meant traveling in a loop.
As pointed out the answer is "no". But that has to do with waves that are electromagnetic as you are thinking of. In that case acceleration is needed to create propagating waves.
But there is more to this than that. Apparently waves of some type do exist even for electrons traveling at constant velocity. And the evidence for that is that electrons, even single electrons exhibit wave behavior such as diffraction at a slit. So if one has an electron beam traveling at constant velocity through space one has to wonder just what it is that causes the statistical paths of electrons to be on average solutions to a wave equation? It's not clear at all why such at thing is true. But it is. But these waves are apparently not electromagnetic in any sense.
If we are talking about outward radiation of real power (not reactive power in the near field), then this energy transmission must take the form of photons. Each photon will have a quantized energy and a corresponding frequency. How can photons have no period (or frequency)? If we restrict the interpretation to classical EM theory, how can a traveling electromagnetic wave not be periodic? Doesn't it need to be a solution of the wave equation?
I too am at a lost on kcdodd's views here. Charges that have a regular oscillation that elect_eng described previously give rise to electromagnetic waves. All electromagnetic radiation are waves, I am not sure why kcdodd would state to the contrary. The only exception I would give is if we are talking about alpha or beta radiation which involves particles. Synchrotron radiation is just an example of highly directed electromagnetic wave excitation.
I am simply stating a definition of radiation as the Poynting vector. If you integrate this flux around a closed surface, and is non-zero, then energy is moving out from whatever is inside the surface. I have said nothing about waves. The poynting vector of a classical em plane wave is periodic in magnitude, but always in the direction of motion indicating the movement of energy. If you accelerate a charge with constant acceleration, then you must be doing work on EM field at a rate proportional to v*a (which is proportional to the total flux of energy out). Nowhere here is a period.
How this relates to photons I cannot answer you.
I disagree with you. There can indeed be a period. Also, any explanation must be related to photons. This is what I tried to do in my first post, yet you chose to shoot it down even though you can't correlate your explanation with simple physics.
I'm OK with your explanation of the Poynting vector, but I disagree with your statement that my description of a radiation pulse is not correct. Imagine that you are a stationary observer and you see a charge accellerating by you. What will you observe from the "Poynting vector"? You will see a radiation pulse as the charge accellerates by you. The charge is initially far away and you see a very small intensity, however when the charge is going by near you, maximum intensity is observed. Then as the charge fades in the distance you see small intensity again. Now think of Fourier analysis. How can a pulse have a period? Well, it can't have one period, but it can be an integration of a spectrum of sinusoidal waves. This is how the solution obeys the wave equation. Superposition applies and the summation of an infinite number of sine waves forms a pulse in the time domain. This is the classical explanation in terms of Maxwells equations. However, in the quantum world, this radiation is interpreted as photons. As an observer, you will see the emission of photons with a broad energy spectrum.
At least that is my opinion. This is the only way I can make sense of your description of the Poynting vector radiating power away (which I agree with), and the well known fact that the energy must disappear as energy carried away by photons (which you should agree with).
Firstly, photons are not "simple physics". If you cannot explain classical events with classical physics, then adding photons and quantum mechanics is not going to help. How do you "simply" explain the electric force on a charged particle with photons? That is out of the scope of this forum.
Second, you do not see radiation of a particle coming directly toward you, only the perpendicular component.(thinking now about this it is hard to believe, but look at a dipole antenna radiation pattern). Granted, if a particle passes you it's distance will go something like tan(angle), and you will get a magnitude change due to the distance effect, but that is not radiation. You would see that even from a particle with a constant velocity that is just passing by.
I suppose you might call that the induction definition of radiation. If a charged particle passes by, you will see a changing E and B, and you can use a "probe" to extract energy, and therefore conclude that radiation exists. However, it is really the probe which is doing work on the field, and so the flux through a surface surrounding the probe will be non-zero. But the flux through the surface around the particle of interest still is zero. So this is not a good definition of radiation.
The magnitude of the poynting vector, like I said already, is proportional to the rate of work done on the particle, which is also proportional to v*a. If acceleration is constant, you will get something like a^2*t (where i just subbed in the velocity as a function of time). If you wish to do Fourier analysis on this function that's fine, but I just don't think it illuminates very much.
edit: I realized there is something wrong with the power relation I have stated here. see my later post.
I did give a conceptual explanation in terms of classical physics. By bringing in the notion of photons, I'm just trying to show an additional point of view. I could avoid any further discussion of photons if it is viewed as out of the scope of this forum, or this thread. It's not a critical part of my view on what is happening here. Still, why ignore the well-known wave-particle duality? It is a useful concept.
In any event, you do make a good point about "explaining classical events with classical physics". I should present a mathematical derivation in terms of Maxwells equations in the classical context. If I don't do this, then I'm just giving an opinion without proof. The weekend is coming up, so I can spare an hour or two to write something up.
If you are inclined, you can also present a more detailed explanations with equations and derivations. It's hard to follow some of your points without more details. Some things are confusing. For example you said "The magnitude of the poynting vector is proportional to the rate of work done on the particle", but some of the work done is used to generate kinetic energy, since any charged particle has mass and velocity is continually increasing. This may just be a wording issue, but equations will make it more clear and leave no ambiguity. There are other examples of confusion I have in interpreting, but I don't want to be nit-picky. -I'm just saying that sometimes equations leave less wiggle-room for misinterpretation.
That sounds good.
By work done on the particle I did mean by the em field. It would probably be better to say the work done on the field by the particle, since the field energy is going up.
That leads to a misunderstanding I realized I have when I posted earlier, and that is the acceleration dependence of radiation power. Apparently it is the second power of a (acceleration), not the first. I only had an intuitive idea that the radiation reaction force on the particle was simply an induction like effect, resisting the change of velocity. Basically, an induced electric field in the opposite direction as acceleration. And so you get work done against this efield as you accelerate putting energy into the field.
In math terms
[tex]\nabla \cdot \vec{S}= - \vec{J}\cdot\vec{E}[/tex]
where, now we have for a particle;
[tex]\nabla \cdot \vec{S} = - q\vec{v}\cdot\vec{E}[/tex]
at the position of the particle, and zero everywhere else.
The electric field on the right hand side, in my mind, was simply proportional to the first time derivative of velocity in the way I already mentioned (so that v and E oppose each other). I am missing where the second power of acceleration comes from. If you go to the power of radiation formula you also loose the velocity dependence, which doesn't seem logical because that seems to indicate you could get radiation power out with no mechanical power in (when v = 0). So, I need to do some homework on where the disconnect is.
I ran across this article which seems interesting and relevant to what you are saying here.
http://www.mathpages.com/home/kmath528/kmath528.htm
It seems there is some controversy about the case of a uniformly accelerating charge. One of the paradoxes seems tied to the equivalence principle. If a uniformly accelerating charge radiates, then a stationary charge in a gravitational field should radiate also. These types of questions are beyond my expertise. For this reason, anything I say should apply to a charge accelerating in one direction, but not necessarily a constant acceleration. The above link makes reference to the first and third derivatives of position. It's also an interesting discussion.
I'm still putting together a derivation and explanation for why an observer would experience a radiation burst with a broad spectrum if a charge accelerates while traveling by in one direction. I've mapped out the approach and it is straightforward and based on the standard derivation of radiation from a short dipole. I'm trying to keep the explanation on the lowest possible level, and also make the explanation clear. Hence, it takes some time to put this together. The approach I'll show allows someone familiar with basic antenna theory to follow.
My basic approach considers that the radiation seen at any particular time is the result of the current from the accelerating charge at one particular section of it's path. This small section can be viewed as a short antenna with a current that is an impulse function. Fourier analysis can be used to represent this current pulse as a broad spectrum (that is, an integral of sinewaves over a frequency band). The full effect of what an observer sees over time is then the integration over the entire path of the charged particle. The overall effect is a pulse of radiation due to distance effect (low radiation intensity when particle is far away), combined with the broad spectrum generated by a current pulse in each short section of the particle's path.
Yes I encountered that "paradox" a while back, but it is not really the issue here. The short answer is uniform acceleration does radiate. But if acceleration is constant, then magnitude of poynting flux is constant (assuming literature is correct), which has a spectrum of a single frequency of zero. I am not really sure how this frequency domain relates to photon frequency domain. Interested to see what you get with a different approach.
A charge undergoing constant linear acceleration over a time interval emits a pulse of radiation. It's a single pulse; not periodic. But the frequency components are periodic. The probability of measuring a particular frequency for an emitted photon is related to the energy amplitude (or rather, the energy per unit of fequency) of the spectrum at that frequency.
This is the particle view in talking about an emitted photon, which I'm not particularly fond of. You might better consider evolving fields which are only quantized upon measurement.
If you restrict it to a finite time interval, then it is not undergoing constant linear acceleration. It's undergoing a step function linear acceleration.
By the way, kcdodd. You can obtain some unphysical results integrating the Poynting vector over a surface. In a periodic electromagnetic wave, the Poynting vector is also periodic, passing through zero. The flux energy2 for a monochromatic wave, for instance, is proportional to the time averaged Poynting vector.
How is that unphysical?
Yes, I agree with that. I just thought this is interesting and relevant to the thread, even if not the real issue. Also, since resolution of this type of issue is more in the realm of a theoretical physicist, rather than an engineer, I don't want my answers to encroach into this area. However, it does seem well established that a uniform charge radiates, so my comments should apply to the constant acceleration case too.
I also ran across another article which claims there is no real paradox, but states that the equivalence principle does not hold for the charged particle. Again, I can't confirm or deny these ideas, I'm just adding them in for the OP to consider.
A PDF of the article can be downloaded here.
http://arxiv.org/abs/gr-qc/9303025
When I looked into this issue I came to the conclusion that the equivalence principle holds just fine. I believe the author there assumed that a stationary charged particle in a gravitational field "weighs" the same as an uncharged particle of the same mass. It does not. The em field associated with the charged particle is not supported by whatever is supporting the charge, and so it creates a stress on the charge, adding an extra downward force making it seem heavier. In the free fall frame this extra force IS the radiation reaction force. The conclusion therefore is that radiation is not present in accelerated frame, but is present in the free-fall frame, which is interesting all by itself.
This statement seems to indicate that you agree with Phrak provided that the charge in not uniformly accelerating over all time. Are your statements limited to the case of uniform (constant) acceleration over all time? Do you acknowledge that the nonuniform case does create a pulse and a broad frequency spectrum? If this is your position, then we are left with the conclusion that you are saying that the effect of the entire particle path over all time is able to effect what an observer sees at one particular instant in time. This is not logical. Obviously, the effect of the future can not be felt in the present, and the effects from the past have already propagated past the observer (at the speed of light).
As I described above, what the observer sees at anyone instant is the effect of one small portion of the particle's path. This is because the current is localized both in space and in time. The current by its very nature is transient even in the constant acceleration case. If you take any point on the path, the current is zero, for all time accept one instant as the charge passes by. There will of course be a delay between the current pulse at that point and the observer (retardation effect) due to the finite speed of light. However, there is a one to one correspondence (or mapping) between a location on the particle's path and the time that the observer sees the effect of the charge as it passes that location.
It's still not clear to me how you are viewing the situation. Perhaps you are considering a frame of reference that moves with the particle. This would be a non-inertial (accelerating) frame of reference and might not be appropriate to consider. Or, at least great care would be needed to make interpretations in this frame.
I hope everyone realizes this all very speculative.
Some of your equations need some help. You used the current density J and substituted qv. J is current density. It is not charge in motion. The units don't match-up either. To obtain J for your Poynting vector equation begin with a charge density rho, and Lorentz boost to obtain a current component.
If you use a classical point particle, both rho and J go to infinity, so it might be better to consider some small charged body.
How did you conclude that a charged particle couples to the vacuum in proportion to av?
Yes, of course I agree that a pulse of acceleration will give a pulse of radiation. Just like periodic acceleration gives periodic radiation, etc.
I find your argument of future effect interesting. However, your example of periodic motion of a particle has the same downfall. The periodic motion must be specified for all time to give you a single frequency. You must specify the entire motion of the particle to do a Fourier transform on its trajectory, whether it be periodic acceleration, a burst of acceleration, or uniform acceleration.
I am considering an inertial frame of reference like a good boy. For the case of constant/uniform acceleration, I am sort of imagining an infinity long cylinder as my "closed surface", where the particle accelerates along the axis of symmetry, and ignoring the ends of the cylinder at infinity since the integral over the end should go to zero.
And Phrak, yes I realize it is current density. There should be a delta function in there. That is why I specified that at the particle, and zero everywhere else. I realized the relation a*v is incorrect. It came from the idea that E would be proportional to dJ/dt (or q*a), and the force would be proportional to E, and so the power into the field, which is F*v, would be proportional to a*v. However, what I was missing is that the self field of a particle is non-linear, and so it can't be solved in that manner. I think the correct relation for this situation is simply a^2, as I already mentioned.
OK, it's good to understand that you are only talking about uniform accelleration.
That sounds like a valid point to me.
OK, so isn's this a fundamentally different thing than what I'm doing. I am considering a fixed observer at a point, much the same way an antenna analysis would be done. We are often interested in the received radiation at a point due to excitation of a distant current source. If you integrate over an infinite cylinder, this is a completely different observation, isn't it?
I still say you need to have radiation with frequencies and a spectrum, but if you integrate over an infinite surface, perhaps you may not see a pulse if you talk about total integrated power. I'm not saying you will or won't - just that the answer is not clear to me and I would do a calculation before giving an answer about power. Have you actually done this calculation? If so, it would be interesting to see it.
  • · Replies 22 ·
  • · Replies 28 ·
