New Reply
Euler's Equations, a freely rotating lamina
Share Thread Thread Tools
Mar25-10, 08:08 PM   #1
Consider a lamina rotating freely (no torques) about a point O of the lamina. Use Euler's equations to show that the component of [tex]\omega[/tex] in the plane of the lamina has constant magnitude.
[Hint: Use the reults of Problems 10.23 and 10.30. According to Problem 10.30, if you choose the direction e3 normal to the plane of the lamina, e3 points along a principal axis. Then what you have to prove is that the time derivative of [tex]\omega[/tex][tex]_{1}[/tex][tex]^{2}[/tex] + [tex]\omega[/tex][tex]_{2}[/tex][tex]^{2}[/tex] is zero.]
2. Relevant equations
The result of 10.23 is that Izz = Ixx + Iyy
The result of 10.30 is that for a lamina rotating about a point O in the body, the axis through O and perpendicular to the plane is a principal axis.
Euler's equations, as given in my book, are
y1W1 - (y2 - y1)w2w3 = N1
y2W2 - (y3 - y1)w3w1 = N2
y3W3 - (y1 - y2)w1w2 = N3
where y is lambda, the eigenvalue, w is omega, W is omega dot, and N is the torque.
3. The attempt at a solution
If the lamina is rotating freely, the N1=N2=N3=0.
If I choose e3 to be normal to the plane of the lamina, then e3 points along a principal axis, and that means that
w3 = constant,
so
W3 = 0.
Those last two statements I'm not sure about.
However, I still know that I would like to prove that the time derivative of w1^2 + w2^2 = 0. That is,
2w1W1 + 2w2W2 = 0
And solving Euler's equations for W1 and W2, with N1,2,3 = 0, you have
W1 = ((y2-y3)/y1)w2w3
W2 = ((y3-y1)/y2)w3w1
Plugging these in to 2w1W1 + 2w2W2 = 0 and doing algebra, I found that, if 2w1W1 + 2w2W2 = 0 is true, then
y2^2 - y2y3 + y1y3 - y1^2 = 0.
Which doesn't seem to necessarily be true.
Help? Thank you!
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr27-12, 11:08 AM   #2
I don't believe that you can assume that w3 is constant. The problem does not state that the lamina is rotating about a principal axis. Instead, use the result you quoted ([itex]\lambda_{3}[/itex]=[itex]\lambda_{1}[/itex]+[itex]\lambda_{2}[/itex]) and use Euler's equations to show that
[itex]\omega_{1}[/itex][itex]\omega_{1}^{.}[/itex]+[itex]\omega_{2}[/itex][itex]\omega_{2}^{.}[/itex]=0
Also, if the lamina WERE rotating about its principal axis that is perpendicular to the surface then the angular velocity would always point along this direction in the absence of torques and[itex]\omega_{1}[/itex] and [itex]\omega_{2}[/itex] would be zero.
Apr27-12, 11:09 AM   #3
Oops. Those dots were supposed to be above omega one and omega two. I'm sure you get the idea though.
New Reply
Thread Tools
Similar Threads for: Euler's Equations, a freely rotating lamina
Thread Forum Replies
Differential equations, euler's method and bisection method Calculus & Beyond Homework 3
Euler's formula and differential equations Calculus & Beyond Homework 2
URGENT HELP! Initial Value Problem Question-Differential Equations and Euler's Method Calculus & Beyond Homework 0
Euler's equations Advanced Physics Homework 9
Using Euler's equations to model ocean waves Classical Physics 0
