Gyroscope Precession - Cause? - From Feynman
The discussion revolves around the causes of gyroscopic precession, particularly in the context of a spinning bicycle wheel. Participants explore various theoretical explanations, visualizations, and the implications of forces acting on the gyroscope during precession.
  • One participant references Feynman's lectures, suggesting that precession involves particles moving in curved paths due to lateral forces, and proposes that the Coriolis force provides necessary torque for circular motion.
  • Another participant describes a scenario involving a spinning disc and the effects of exerting torque at specific points, indicating that particles acquire speed components in different directions during precession.
  • A participant questions the claim about speed acquisition, asserting that the velocity of particles on a rotating disc remains constant, while also noting the out-of-plane component due to precession.
  • There is a disagreement regarding the direction of movement of particles at the 12 o'clock and 6 o'clock positions, with one participant asserting that the 6 o'clock position moves down and the 12 o'clock position moves up, while another participant contests this view.
  • Another participant introduces a model involving quadrants of motion in relation to the swivel axis, suggesting that the gyroscope's mass behaves differently depending on its position relative to the swivel axis, leading to a tendency to pitch.
Participants express differing views on the mechanics of precession, particularly regarding the effects of forces and the direction of particle movement. There is no consensus on the explanations provided, and multiple competing models are present.
Some claims rely on specific assumptions about the forces acting on the gyroscope and the definitions of motion in different quadrants. The discussion includes unresolved questions about the nature of torque and centripetal forces in the context of gyroscopic motion.
Pradhan34
I ran a search for gyroscopes looking for a definitive solution to the "What causes Precession?" and found no good clear answers. I think the Feynman lectures come close to the solution and followed that thought process, all the pieces point to the solution, I had to put my theory to the test on this forum. Please have some patience while reading this cause its long.
Feynman, From Lectures on Physics Volume 1 – “Rotation In Space”,talking about precession, quote “...When the wheel is precessing, the particles that are going around the wheel are not really moving in a plane because the wheel is precessing...the particles which are crossing through the precession axis are moving in curved paths, and this requires application of a lateral force. This is supplied by our pushing on the axle, which then communicates the force to the rim through the spokes... What about the particles that are going back on the other side...there must be a force in the opposite direction on that side. The net force we apply is zero.” The Visualization is given in first image from left attached below.
(This discussion is of precession of a bicyle wheel)
This quote was rather ambiguous and I resolved to see if 2D drawing of the precessing wheel did more justice. I drew it in Solidworks 2D drawing (Picture attached below –second from left below), and voila, a point precessing and also moving on the wheel does not move in a circle – but on a curve(each point(total 3) has it’s respective circle drawn – green, red, black – the black circle is the trace of the center of mass of the wheel, thus the point’s shadow lies on the center of mass at that point). To move along a circle an object needs centripetal force and a linear momentum (Without the linear momentum it isn’t going to move). But for a curve we need a centripetal force and a torque – the torque given by the coriolis force. When the wheel moves along the curve there must be a velocity, radial, moving the wheel element towards the center resulting in a coriolis force perpendicular to the radial velocity and being perpendicular provides the coriolis force a moment arm equal to the radius of the circle.
How does this result fit? In a demonstration of precession, we hold the string, spin up the wheel and release it. Nowhere do we give it the linear momentum it needs to go around the precession axis. The coriolis force provides just this torque, to push the wheel into the circular motion. While the centripetal force and its moment arm – the radius of the wheel (NOT THE PRECESSION RADIUS) - balances the torque due to gravity. Thus the torque due to gravity furnishes the centripetal force just as friction between car wheels and the road provide centripetal force to make a turn.
Now come the pitfalls,
This works really well for the top section. But reading the Feynman quote above –“ What about the particles that are going back on the other side...there must be a force in the opposite direction on that side. The net force we apply is zero.” So far we, think the torque due to gravity is a torque. But actually is a couple (the string tension and mg form a couple turning it clockwise ). So there must be a centripetal force 180 degrees to the one on the top. I can’t see it. I was hoping by placing this on the forum someone might figure it out.
If someone has a good apparatus, maybe you can do some rough calculations.
The coriolis force, the torque giving it linear momentum...fits too well to discard, I think i’m just not seeing it.
Then again I could be farting my *** off, twisting facts. So let me know, And thank you for reading this far. I could explain the coriolis force part in more detail if someone requires.
I'll try a quick explanation, without following your whole though process. Let's say you have a disc facing up and spinning clockwise. Imagine the face of a clock hovering over the disc. You exert torque and try to push the disk down at 3 o clock and up at 9 o clock. All the rotating particles on the left side acquire a speed component upwards from that force and all the particles on right acquire a speed component downwards. The most speed the have acquired when they reach 6 a clock and 12 o clock. The particles at 12 o clock move up and the ones at 6 o clock move down although you are pressing down on 3 an pulling up on 9.
0xDEADBEEF said:
The most speed the have acquired when they reach 6 a clock and 12 o clock. .
This part i didn't get. The Most speed? if the disc is rotating clockwise with a angular velocity w. the velocity is constant for a particle rotating on the circumference of the circle. v=rw: r=radius=constant
Are we considering a gyroscope effect here? if we are then using the vectors for precession, we get: 12 o clock will move down (or rather turn down) and 6 o clock will move up.
But the disk is precessing, so there is an out of plane component for the speed that we are talking about.
No it won't. 6 o clock will move down and 12 o clock will move up. With vectors it is the same. The angular momentum vector points down, according to the right hand rule (fingers in direction of spin, thumb in direction of vector) The torque vector points from 6 o clock to 12 o clock (same rule). Hence by vector addition the tip of the angular momentum vector will be pushed towards the 12 and the spinning axis follows.
I attach an image to illustrate the physics of gyroscopic precession. The image is from the http://www.cleonis.nl/physics/phys256/gyroscope_physics.php" page on my website.
In order to have some reference I will have the gyroscope wheel spinning along a horizontal axis, just like in the well known demonstration of the spinning bicycle wheel.
Defining the following names:
Roll - spinning of the gyroscope wheel
Pitching - turn along a horizontal axis, perpendicular to the roll
Swiveling - turn along a vertical axis.
First start the gyroscope wheel spinning fast. Then add some swivel.
Think of the gyroscope wheel as moving through four quadrants. In two of the quadrants the wheel's mass is moving towards the swivel axis, in the other two quadrants the wheel's mass is moving away from the swivel axis.
In the quadrants where the wheel's mass moves towards the swivel axis a force is required to reduce the velocity of rotating around the swivel axis. If that force isn't present the mass in that quadrant will tend to move in the direction of the green arrows in the image.
In the quadrants where the wheel's mass moves away from the swivel axis a force is required to increase the velocity of rotating around the swivel axis. If that force isn't present the mass in that quadrant will tend to move in the direction of the green arrows in the image.
The inertial effects in the four quadrants combined give rise to a tendency to pitch.
Summerizing:
If a gyroscope wheel is spinning fast (rolling) and some swivel is added, then the gyroscope wheel will tend to pitch.
(Also, note the counterpart: if the wheel is spinning, and some pitching motion is added, the wheel will respond with some swiveling motion.)
In the case of the well known suspended spinning bicycle wheel: note that its precessing motion gives rise to a tendency to pitch up. Gravity is tugging at the wheel, but the tendency to pitch up nullifies the gravitational influence.
The full story is in the http://www.cleonis.nl/physics/phys256/gyroscope_physics.php" article on my website.
Cleonis
  • · Replies 49 ·
  • · Replies 39 ·
  • · Replies 35 ·
