Rate of Change of electric field
The discussion focuses on calculating the rate of change of the electric field (dE/dt) in a parallel-plate capacitor with a current of 3.8 A. The relevant equations include V = E*d and the relationship between capacitance (C), charge (Q), and voltage (V). By substituting C with the expression C = (ε₀ * A) / d, where A is the area of the plates, the final equation for dE/dt is derived as dE/dt = (I / (ε₀ * A)). This approach emphasizes the importance of understanding the relationship between current, charge, and electric field in capacitor systems.
  • Understanding of parallel-plate capacitors
  • Familiarity with electric field equations
  • Knowledge of capacitance and its formulas
  • Basic calculus concepts (for advanced understanding)
  • Study the derivation of capacitance for parallel-plate capacitors
  • Learn about the relationship between current, charge, and electric field
  • Explore the implications of ε₀ (permittivity of free space) in electric field calculations
  • Investigate the role of calculus in physics problem-solving
Students in introductory physics courses, electrical engineering majors, and anyone interested in understanding the dynamics of electric fields in capacitors.
sdoyle1
At a given instant, a 3.8 A current flows in the wires connected to a parallel-plate capacitor. What is the rate at which the electric field is changing between the plates if the square plates are 1.76 cm on a side?
I don't really know where to start...
Could you use the change in length=perm of free space(I +E(sub o)*Change in E) ? I don't know if this is even an equation..
For a parallel-plate capacitor, you can write the potential difference across the plates as
V = E*d
with as the potential difference, E as the electric field, and d as the separation distance. You can rearrange for E
E = V/d
If you look at V, we can relate it to the capacitance, C, by the definition C = Q/V. This becomes V = Q/C
E = Q/(Cd)
If we take the rate of chance of the left hand side and right hand side with respect to time,
dE/dt = 1/(Cd)*dQ/dt, but dQ/dt = I = the 3.8A you were given.
We can then replace C with the expression you attempted, C = ([tex]\epsilon[/tex]o)*(A/d) (this only holds for parallel plates!), cancel d, and we're left with an equation for dE/dt (rate of change for the electric field) with constants and your given quantities, I and the area, A.
makes so much sense with calculus.. our prof doesn't want us using calc b/c its not advanced 1st year physics.. I didn't think about deriving the equation, just assumed there was one already set.. thanks so much!
  • · Replies 26 ·
  • · Replies 20 ·
  • · Replies 18 ·
