Electric Potentials (4 charges on corners of a rectangle)
The problem involves calculating electric potentials at specific points (corners of a rectangle) due to multiple point charges. The rectangle has defined dimensions, and the charges are located at the corners, with one charge being unknown. The discussion also includes the work required to move a charge between these points.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the calculation of electric potentials due to point charges and the superposition of electric fields and potentials. There are questions about the relationship between electric fields and potentials, and how to approach the problem given the rectangle's geometry.
Some participants have provided insights on calculating potentials and electric fields, while others express confusion about the implications of superposition and the geometry of the rectangle. There is an ongoing exploration of how to approach the calculations for points A and B.
Participants are navigating the complexities of the problem, including the unknown charges and the specific geometry of the rectangle, which may affect their interpretations and calculations.
Unto
A rectangle has sides of length 5cm (right and left) and 15cm (top and bottom).
Top left corner has charge (q1) = -5uC
Top right corner has charge A = ?
Bottom left corner has charge B = ?
Bottom right corner has charge (q2) = 2uC
a) What are the electric potentials of A and B
b)How much external work is required to move a third charge (q3 = 3uC) from B to A along the diagonal of the rectangle
Not too sure. For part b I'm thinking I would use a line intergral and say that the diagonal path from A to B is equivilent to going from B to q1, then q1 to A.
V = U/Qo
But where will I get U (potential energy) from?
What I really want is part a, once part a is done I can just do some line intergrals to find the work done for part b.
Do I use equipotentials? So potential of A is the same as potential of q1? B is the same as q2?
Any pointers and I'm very grateful.
Calculate the potential due to a point charge as a function of distance. The potentials add at any given point in space. How is the electric field created by a point charge related to the potential?
I'm still confused sorry. Say if I wanted to find the potential of A, which is in the top right corner. It is inbetween two different fields created by charges q1 and q2. I cannot just find the electric field of one, then say 'since A is a distance r from this charge it's potential is this'? It doesn't make sense. Don't fields superimpose?
And the fact that I'm working with a damn rectangle makes it more harder to interpret.
Please, more help :(
Electric field of q1 at B: -1.8E7 Nc-1
Electric field of q1 at A: -2E6 Nc-1
Electric field of q2 at B: 8E5 Nc-1
Electric field of q2 at A: 7.2E6 Nc-1
K so these are the electric fields using the distances on the rectangle. Now to find the potentials of A and B, how to do this?
K, A and B are just corners... Hmm..
Electric fields superimpose and so do potentials. Potentials are scalars so the superposition is straightforward. You should be able to find the potential of a point charge anywhere in space from
[tex]V=-\int^r_\infty\vec{E}\cdot\mbox{d}\vec{r'}[/tex]
and Gauss's Law can be used to find the E field of a point charge as a function of r. The upper limit r is the distance from the point charge to a corner.
  • · Replies 24 ·
13K
