What are the differences between the filter and net approaches in topology?
  • Context: Graduate
  • Thread starter Thread starter Kalimaa23
    Filters Topology
The discussion revolves around the differences between the filter and net approaches in topology, with a focus on understanding these concepts without delving too deeply into technical details. Participants explore the implications of each approach and share insights on learning resources.
  • Homework-related
  • One participant, Dimi, seeks clarification on the differences between filters and nets in topology, mentioning that their professor favors the filter approach.
  • Another participant suggests that filters and nets are only part of the broader topic of topology and encourages Dimi to start with any available textbook, regardless of the approach it takes.
  • A filter is described as a generalization of convergence, with specific definitions provided, such as the conditions for a family of sets to be considered a filter and the concept of convergence to a point.
  • The participant elaborates on the idea of filters, noting their generality and how they can represent convergence without needing countability or an index set.
  • Definitions of open and closed sets in topology are mentioned, emphasizing that these concepts are defined abstractly without reliance on metrics.
  • Dimi acknowledges that their professor has subtly introduced the filter concept in previous courses, indicating an understanding of the pedagogical approach taken.
  • There is a light-hearted comment about mathematicians being "devious" in their teaching methods, reflecting on the aesthetics of mathematics and the professor's teaching style.
Participants generally agree on the importance of understanding both filters and nets in topology, but there is no consensus on which approach is superior or more beneficial for learning.
Some definitions and concepts may depend on specific interpretations or contexts within topology, and there may be unresolved aspects regarding the application of filters and nets in different scenarios.
Kalimaa23
Greetings,
Having decided on a physics/math double major next year, I decided to get a head start this summer.
After tackling some classical mechanics, my next target is topology.
My problem is the following: I have been informed that there are two approaches to the subject, one involving filters and the other one involving nets (note that these terms are directly translated from Dutch, if other terms are used in English I apologize).
I've been told my topology professor for next year favours the filters. I have found some textbooks online, but a friend has told me they use the net approach.
My question is this: could somebody explain to me the difference between the two approaches, without going into too much detail. Also, it would be greatly appreciated if someone could point me in the direction of any online textbooks that deal with the filters approach.
Thanks in advance,
-Dimi
Originally posted by Dimitri Terryn
After tackling some classical mechanics, my next target is topology...
My problem is the following: I have been informed that there are two approaches to the subject, one involving filters and the other one involving nets...
I've been told my topology professor for next year favours the filters...
Filters and nets are only a part of the story, not the whole of topology. My idea is to get whatever book you can and start with it. Dont worry so much about whether your first book takes exactly the same approach as your professor.
This might help get you started. A FILTER is just a generalization of the idea of convergence to a limit. You know about convergent sequences of real numbers and you probably can define the LIMIT of a sequence.
Here are some definitions:
In fact I believe these are the three main definitions about filters!
A FILTER is a family F of non-empty sets which satisfy the condition: If A,B are sets in F, then there is a set C in F which is contained in A intersect B.
A filter F is said to CONVERGE to the point x provided each neighborhood of x contains a member of F.
A space is said to be COMPACT provided each filter consisting of closed sets is contained in a convergent filter.
Here are an auxilliary definition which the Prof may or may not use, and another way of defining compactness:
A filter F is said to CLUSTER at the point x provided each neighborhood of x intersects a member of F.
A space is compact if and only if each filter consisting of closed sets clusters at some point.
Now let us be realistic. The definitions probably sound very abstract when one hears them for the first time! So think of a sequence of numbers
{an}
And construct a family of sets F = {AN} which are just
the "tails" of the sequence
AN = {an for all n > N}
F is now a set of sets of numbers
F is the set of "tails" of the original sequence
Check that F is a filter.
The idea that the original sequence converges to a number x is the same as the idea that the filter F converges to x.
What is clever about the idea of a filter?
The generality. A filter does not have to be countable
and it does not have to have an index set like 1,2,3,4,...
The set of sets take care of ordering themselves by inclusion.
It can be used for other things. It is in some way the most
simple and general picture of convergence, with the least
unnecessary detail.
However, because it looks weird and strange when you first see it, no one can at first understand why the professor should introduce such an idea and there will be 2 or 3 days of confusion.
The first definitions of topology are the "open sets"
The space X has a family of open sets satisfying the condition
that the union of open sets is again open
and the finite intersection also.
And the "closed" sets are the complements of open sets.
The intuitive idea of a closed set is one which includes its border.
But all this is being defined without the help of a metric or distance! Thus one has these abstract definitions in order to finesse things like "border" and "converges to a point" and "continuous function" which would be very easy to describe if one had the help of a distance measurement.
Go ahead and learn about open and closed sets. Any online textbook for pointset or general topology should be useful.
Nets and filters are no big deal and should not make you wait
at the door
Thanks for the info. From your examples I can see now that the professor in question (she thought our freshman multivariable calculus course) has already nudged us towards the filter idea, if subtly...
Mathematicians, devious they are:wink:
Edited to account for blatant spelling errors
Thanks for the info. From your examples I can see now that the professor in question (she taught our freshman multivariable calculus course) has already nudged us towards the filter idea, if subtly...
Aesthetics is basic in mathematics and this professor sounds like she might have good taste. If so, my compliments on your good fortune.
(edited to correct for tendency to wander off topic)
  • · Replies 21 ·
9K
15K
