| Thread Closed |
What ACTUALLY causes a magnetic field to be generated when there is a current? |
Share Thread | Thread Tools |
| Mar30-10, 06:40 PM | #1 |
I have asked a few people this question and the most common answer is, "that just seems to be the way nature works." That definitely is not good enough. What is the physical REASON why a magnetic field is generated when a current is running through a wire?
Thanks! ~Matt |
| Mar30-10, 06:51 PM | #2 |
That just seems to be the way nature works.
Teehee. Really though, that's about as good as you'll get. Why does an accelerating charge produce light? Why does mass generate a gravitational field? The best physics can tell you is what mediates or mathematically describe what is going on. At some point you just have to accept something exists. |
| Mar30-10, 06:57 PM | #3 |
Mentor
| Mar30-10, 07:22 PM | #4 |
Mentor
Out of idle curiosity, what sort of answer would be good enough?
| Mar30-10, 07:25 PM | #5 |
Watch this video: http://www.youtube.com/watch?v=wMFPe-DwULM
| Mar30-10, 07:49 PM | #6 |
| Mar30-10, 09:11 PM | #7 |
1. Fantastic discussion, thank you for the question.
2. Fantastic video. That guy... he's smart. And he brings up the natural question: if we don't yet understand why our hand doesn't go through the chair, then we're hopeless to know why there is a magnetic force. 3. As an exercise for (super-) theoretical physicists, I would ask this question: How many arbitrary force fields could we assign to the universe which would obey the "conservation of energy" as we know it. What I'm saying is, since the electrical, strong/weak, magnetic, and gravitational forces are all "arbitrary" or "axiomatic" (as far as our understanding of them goes), I wonder how many different kinds of force fields there could actually be? Might a different universe have different force fields? I agree with you Matt. The equation F (magnetism) = qv x B is very curious. The equations for determining the magnetic field B are even more curious. Unfortunately, I don't see how we can ever get past the fact that our understanding of the universe is limited to our perception of it. We didn't come up with those equations on a chalkboard! We came up with them after years of rigorous, painstaking experimentation. |
| Mar30-10, 11:44 PM | #8 |
To put in complicated terms.. "consider the electron in the lab frame... when it moves you record a current and a mag. field.. on move with the electron's reference... you can see ONLY a time dependent electric field.. all electrons in the current will generate a superimposed field that will..show as a mag field.." ..this is a really confusing answer given by a certain physicist... the simplest explanation is...THE ELECTRON IS MOVING....since we know electric and magnetic fields are two facets of the same coin..from maxwell's laws..only seen completely in different frames.. it just depends on how you see it..if ur the experimenter..u'll see a force [qv B]...but while moving with the electron you will see a electric field..E(t).. that's my take on it.. |
| Mar31-10, 01:10 AM | #9 |
If you ask "why is the sky blue?" or "why does a current generate magnetic forces?" An investigation into more and more details forces you further and further back in more "why" questions as Feynman explains in detail, until you are simply left with answers that the sky is blue because God made it that way! And then one has reduced a scientific question to a religious one. On the other hand if you ask HOW is it that the sky appears blue you have a different question. It is the one that Feynman is avoiding presumably because he doesn't want to say on TV that physics does not have "all the answers". And of course most people know that for light coming through the atmosphere we have a MODEL and by using that model we achieve an ANALOGY between that we do not know and that with which we are familiar. If we say the unknown acts like this other thing we know well, then we feel we have a certain handle on the unknown. And we do. For example, one can use our model to predict results in circumstances that we've never tried in an unknown phenomenon. That is downright practical! We still don't know "why" things act as they do but we do have a handle on "how" they act! Fine. So now when you ask the question what "actually" causes the magnetic field from a current, you really are asking "why does a current produce magnetic forces about itself?" Can't answer. "Why" questions are off-limits. Well, then, HOW does it do it? Well the usual approach is to flood you with mathematics. And that would be because the "model" that explains the phenomena is a mathematical model. But for you that isn't quite what you mean is it? Because a mathematical model is just an abstract creation with no anchor in reality. What you are asking is to understand the thinking of Maxwell who created the mathematics by using an analogy with the flow of fluids. And his model even invented a fluid to fit the bill they called "aether". And for a time people were satisfied with that as a "how". But as time went on and more things were measured, it was discovered that while the mathematics still predicts correct answers, the fluid model began to fail and soon it was totally rejected. Thus the problem from your point of view is that at present there simply is NO analogy that one can use for a model to "explain" how a magnetic field works. There are no "fluids" moving from here to there delivering forces or energy. There are no familiar mechanisms that we can recognize and instantly understand how a current delivers a magnetic force at a distance delayed by the speed of light. That model is today simply missing. For that matter we even know the mathematical model is not correct at all scales of measurement. So what is a "magnetic field"? Well, a field is a mathematical description of vectors over a region of space. In this case it is force vectors. So then a magnetic field is really just the "behavior" of those forces say about a current-carrying wire. But here's the fly in the ointment: Today there is no model to say HOW those forces arise. Therefore physicists make the illogical claim that these fields ARE "behavior"! They call them "behavior fields". Don't forget the forces are real and exist. So how does an object consist of only it's behavior? It's creating something out of nothing. It's illogical. It's as illogical as saying light waves are propagated without any medium. So the bottom line is that with no model, behavior alone is accepted as an "object". So what you've discovered is that scientists really don't like to stand up in front of the world and say "we really don't have any idea "how" that works. What they'll always say, is: "Here, let me tell all the things we DO know about that, whether relevant to your question or not!" But don't expect science to hand it all to you on a silver platter. If there's no model that's working for some phenomenon, then it's up to YOU to think about it and try to understand HOW it all could work. Maybe you'll be right. Maybe you'll be wrong. But that is what science is all about. |
| Mar31-10, 02:44 AM | #10 |
I wouldn't say it's quite fair to characterize the aether concept of Maxwell and other prominent scientists as being a type of fluid. I think they all very much realized it could not be a fluid as we know them. Nor some type of super-gas which had been mentioned probably more often in those days. But the differential equations describing EM have pretty much the same form as for fluid behavior.
Maxwell and subsequent physicists actually built mechanical models of the aether using cog wheels and belts and such. They obviously didn't confuse them with the actual behavior of the medium but used them as a crutch to form a more concrete idea of the stresses and movement of energy. Stress is probably the most powerful word to apply to magnetic behavior. Moving a charge causes flow of energy into a region of the medium and therefore causes a stress or build up of potential energy there. Nature urgently wants to remove stress whenever possible (just like us). So apparently she counteracts by venting the energy away from the built up region by forming a counterflow of magnetic energy. It wouldn't work to have a counterflow in the opposite direction as that would only increase or double the stress in the region that energy has moved from. So nature's only recourse is to create a neutralizing flow at 90 degrees. |
| Mar31-10, 03:53 AM | #11 |
the first two answers gave you quite the best explanation.
the magnetic field was and still is a miracle of nature because it does not exist so often in nature. and the only thing you could explain about it is why on some places there is a field and on others not. the best answer so far, after being considered by great minds as faraday maxwell and who else not is that when charge is not moving there is no mag field and if it does there is. and thats the most natural explanation there will ever be because movement is sort of a structural basis for everything we experience. |
| Mar31-10, 05:07 AM | #12 |
By the way Matt, occasionally there is a post or two here encouraging a person to dig deeper and investigate things that have no clique answer. That's really how science works when it is functioning. I think you realize that you do not have to belong to the old gentleman's complacency club. I hope you never settle for less than your perceptive mind tells you it should.
| Mar31-10, 05:33 AM | #13 |
Thanks a lot for the video man !
| Mar31-10, 10:05 AM | #14 |
VERY good and informative answers everyone! This kind of thing is what fascinates me so much in Physics!!
| Mar31-10, 10:43 PM | #15 |
And let me add that Maxwell's mechanical model of an electrical transformer is quite a thing to behold! You'll find it on page 228 volume II of the Dover edition of Maxwell's Treatise on E&M. [Maxwell's section 584] It is an excellent "crutch" or what I'd call a "thinking tool" to help understand the rather strange behavior of transformers. But then "thinking tools" are really what all physical models really are! |
| May12-10, 07:31 PM | #16 |
Well, in order to explain correctly what is magnetism, you need relativity. Math is a bit hard, but the concept is easy:
Coulomb's law is only valid for electrostatics. When you move a charge, part of the electrical field is "transformed" to magnetic force. It's like the components of a vector when you rotate your referential, part of one component is transformed into another component. So, in essence, electricity and magnetism aren't as far apart as it sometimes seems to be when you look at the equations. |
| May12-10, 11:10 PM | #17 |
I might be reading too much into this question, but it seems like the OP was trying to understand the fundamental cause of magnetism. And for the record, to the OP and to everyone else, "that's how nature works" is always a horrible answer because it doesn't tell you anything. You're just stating the obvious. "Magnetism has something to do with the alignment of spin" could have been a better starting point than the dismissive tone the OP encountered...
| Thread Closed |
| Tags |
| magnetic field |
| Thread Tools | |
Similar Threads for: What ACTUALLY causes a magnetic field to be generated when there is a current?
| Magnetic field generated by current in semicircular loop at a point on axis | Advanced Physics Homework | 4 | ||
| Magnetic Field generated by a wire | General Physics | 4 | ||
| Magnetic field generated by a circular current loop | Classical Physics | 12 | ||
| AC vs DC Generated Magnetic Field | General Physics | 3 | ||
| Magnetic field generated by a metal plate | Introductory Physics Homework | 1 | ||
