Faraday's Law: Conducting rod moving across a magnetic field
The discussion focuses on applying Faraday's Law to a conducting rod moving through a magnetic field. The induced electromotive force (emf) is calculated using the formula EMF = B * d * v, where B is the magnetic field strength (0.500 T), d is the distance between the rails (0.260 m), and v is the velocity of the rod (6.80 m/s). The current can be determined using the relationship F = I * d * B, where F is the constant force (3.40 N) applied to the rod. Participants noted that the sign of the calculated values was crucial, leading to the realization that the sign convention must be correctly applied to avoid errors.
  • Understanding of Faraday's Law of Electromagnetic Induction
  • Familiarity with the concepts of electromotive force (emf) and magnetic flux
  • Knowledge of the relationship between force, current, and magnetic fields (F = I * d * B)
  • Basic principles of circuit resistance and Ohm's Law
  • Study the derivation and applications of Faraday's Law in various electromagnetic scenarios
  • Learn about the implications of changing magnetic fields on induced currents
  • Explore the concept of resistance in circuits, particularly in dynamic systems
  • Investigate the role of sign conventions in physics calculations and their impact on results
Students and educators in physics, particularly those focusing on electromagnetism, as well as engineers working with electromagnetic systems and circuit design.
choco_moo
A conducting rod is pulled horizontally with constant force F= 3.40 N along a set of rails separated by d= 0.260 m. A uniform magnetic field B= 0.500T is directed into the page. There is no friction between the rod and the rails, and the rod moves with constant velocity v= 6.80 m/s.
1. Using Faraday's Law, calculate the induced emf around the loop in the figure that is caused by the changing flux. Assign clockwise to be the positive direction for emf.
2. The emf around the loop causes a current to flow. How large is that current? (Again, use a positive value for clockwise direction.)
EMF = -d Φ/dt
Φ = ∫(B·dA)
1. I didn't expect this to work, but I tried to use the formula E = BLv. I plugged in B, d, and v and the answer was wrong.
A hint was given: When the magnetic field is uniform and normal to the plane of the loop, then the flux is of the product of the field and the area. In this problem it is the area that changes with time, not the field.
Even with the hint I'm still confused. Since area is changing with time, how do I incorporate that into my calculation?
2. I first tried using F = IL x B to solve for I but it was wrong. The hint said Remember F=ma: since v is constant, a=0, so it must be true that the net force on the rod is zero. The pulling force is compensating the force on the rod due to the current through it and the magnetic field.
So what does this mean? I'm so confused on what to do.
Any help is appreciated!
Honestly, it sounds to me that you are doing it correctly.
For part 1, the time derivative of the area will be [tex]d\; v[/tex]. So why wouldn't the correct formula be [tex]EMF=B\; d\; v[/tex]? The only place to make a mistake is with the sign, but the magnitude should be correct.
For part 2, normally the current would be the EMF divided by the resistance of the loop, but you do not know the resistance. However, you have correctly noted that the forces are balanced so the formula [tex]F=I \; d \; B[/tex] should enable you to calculate current [tex]I[/tex]. You can even go one step further and calculate the resistance of the loop as [tex]R={{d^2\; B^2 \; v}\over {F}}[/tex]
I don't know. Maybe we are both overlooking the same thing. Are you sure that your answer is wrong?
Something else bothers me here. Notice that the formula for resistance above shows the resistance is constant since d, B, v and F are all constant. However, if the perimeter of the loop is increasing, the resistance of the loop should also be increasing. Hence, it seems that you can not have a constant force balance as suggested in the problem. Again, maybe I'm overlooking something, and perhaps this last comment becomes a clue to the real solution. But, I must honestly say that I think there is an issue with the problem and with the answers you have been given.
EDIT: Although not explicitely stated in the problem, it seems that the rails are conductive, otherwise no current will flow.
This time I tried using negatives for my answers and guess what, they're right! So this whole time, it was a sign problem. However, I don't really understand why they're negative. Can you explain why?
