Rigid Body Motion: Sphere on Inclined Plane
The problem involves a sphere of mass M and radius R that is given an initial velocity Vo on an inclined plane with angle theta and a friction coefficient mu. The objective is to find the position of the ball as a function of time, considering different cases of motion (slipping vs. rolling). The discussion revolves around the application of work and energy principles in the context of rigid body motion.
  • Participants discuss the conditions under which the sphere may be slipping or rolling without slipping. There are attempts to derive a differential equation using conservation of energy and work done by friction. Questions arise regarding the simplification of the moment of inertia and the relationship between linear and angular velocities.
The discussion is active, with participants exploring different cases based on the friction coefficient and the angle of the incline. Some guidance has been offered regarding simplifying the equations and considering specific cases, but no consensus has been reached on a complete solution.
Participants note the need to analyze two distinct cases based on the friction coefficient relative to the angle of the incline. There is also mention of the complexity of the resulting differential equation, indicating potential constraints in the problem's scope.
hellsnake
A sphere of mass M and radius R it`s given a velocity Vo on the base of a inclined plane (theta being the angle) and friction coefficient mu (you may assume that static and kinetic friction are equal) Find the position of the ball as a function of time
Welcome to PF!
Hi hellsnake! Welcome to PF! :smile:
(have a theta: θ and a mu: µ :wink:)
(and btw, is the sphere skidding, or is it rolling without slipping?)
Use work done and conservation of energy …
what do you get? :smile:
It doesn'st tell you if it's slipping or not you have to see that. By the way I forgot you have to study the two cases when µ≤ 2/7 tan θ and µ≥ 2/7 tan θ. Without the equal. And when I do conservation of energy and work done by friction I get this differential equation
(1/2)M.(Vcm)² + (1/2)Icm.w² + MgH - (1/2)MVo² = -Ffr X(t)
But Vcm= (d/dt)X(t) and H=X(t)sin θ . Then I get that
(1/2)M.(d/dt)X(t))² + (1/2)Icm.w² + MgX(t)sin θ - (1/2)MVo² = -Ffr X(t)
Where:
M= mass of the sphere
Vcm= It's the velocity of the center of the mass
Icm= It's the moment or inertia with an axis that pass through the center oh the sphere
w= It's the angular velocity
H= It's how high is the sphere measure from the floor
Vo= It's the initial velocity
Ffr= It's the force that the frcition does
X(t)= It'sthe position of the ball measure from the point where it start his motion. And I choose the X axis parallel to the motion
So if I read the equation I get that the energy on a arbitrary point of the sphere is equal to
(1/2)M.(Vcm)² + (1/2)Icm.w² + MgH. Now this minus the energy in the initial moment(the sphere doesn't have rotational energy here) (1/2)MVo² . All of this is equal to the work done by friction -Ffr X(t)
I think that I have to do another thing because this differential equation It's too hard for this course I think. However if you have the solution for this equation I appreciate it too
Thanks a lot in advance
Hi hellsnake! :smile:
(have an omega: ω :wink:)
You can simplify it slightly by writing Icm in terms of M and R, and writing Ffr = µMg.
After that, you need a relation between V and ω … try the easier, rolling-without-slipping case first: V = Rω. :wink:
(and after that, you'll need to find the condition on µ for rolling … presumably it's going to be µ ≥ 2/7 tanθ ! :rolleyes:)
  • · Replies 18 ·
