Need help wiring a solar panel to electric motor
This discussion focuses on safely wiring a 4W 12V solar panel to a 12V DC 15 RPM High Torque Gear Box Electric Motor. Key recommendations include using a 1A fuse placed close to the battery terminal to prevent short circuits and potential fires. Additionally, a Schottky diode is essential to prevent the battery from back-feeding into the solar panel, which could damage the panel. Proper wiring configuration is crucial, with the solar panel connected in series with the diode, and the battery connected in parallel with the fuse and motor.
  • Understanding of basic electrical concepts, including voltage and current.
  • Familiarity with solar panel components and their functions.
  • Knowledge of fuse ratings and their importance in circuit protection.
  • Experience with wiring diagrams and schematic representations.
  • Research the specifications and installation of Schottky diodes for solar applications.
  • Learn about proper fuse selection and installation techniques for DC circuits.
  • Explore wiring diagrams for solar panel systems to understand safe configurations.
  • Investigate the characteristics and requirements of 12V DC motors in solar setups.
This discussion is beneficial for hobbyists, DIY enthusiasts, and anyone interested in solar energy applications, particularly those looking to safely integrate solar panels with electric motors.
dogsnuts
Hi everyone,
i want to make sure that when i wire this all up I am not going to start a fire :)
So, I've got a 4W 12V solar panel the unit produces up to 333mA
a 12V battery and a 12V DC 15 RPM High Torque Gear Box Electric Motor.
I'm a newbie so don't much about electronics. All i want is for the motor to run and not blow me up.
Can someone please walk me though what needs to be done, or what i need to buy if what I've got is wrong.
Thanks in advance
I guess that, to be on the safe side, you should put a 1A fuse on the lead to the battery, right next to the battery terminal. The solar panel won't be capable of "blowing up" anything but a car battery can supply hundreds of Amps into a short circuit, if one should occur and could melt any leads and start a fire. A low value fuse will take care of that risk.
A few things would be important here. I agree with sophiecentaur that a fuse is very important. But more than that, get a Schottky diode for the solar panel (schottky because of low voltage drop). I don't know what kind you have. It may have one built into it. But be sure. You don't want the battery to back-feed into the panel. It will burn it up if you're not careful.
Also, a lot of this depends on how you're hooking it up. If you have a solar panel with a diode in series then the battery in parallel with a fuse in series (and a switch hopefully) and then the motor, you should be fine. It may be wise to post a schematic of what you're doing if possible. Panels can get expensive, so you don't want to blow a bunch up.
Justin Coulston
justin.coulston@gmail.com
TheModernEngineer.blogspot.com
