How can I calculate the mechanical resistance of a generator for my DIY project?
  • Context: High School
  • Thread starter Thread starter bonna
    Generators Resistance
The mechanical resistance of a generator is influenced by the electrical load it supports. For an ideal generator, when no appliances are connected, the mechanical resistance is zero. To calculate the force required to drive a generator, apply the law of conservation of energy, factoring in the power consumption and an additional 40% to account for friction and heat loss. The formula to determine the force in Newtons is: force = (watts required x time in seconds) / (circular distance in meters).
  • Understanding of electrical power calculations (watts)
  • Familiarity with mechanical concepts (force, distance, time)
  • Basic knowledge of generator operation principles
  • Ability to apply the law of conservation of energy
  • Research the principles of mechanical resistance in generators
  • Learn about friction and heat loss in electrical systems
  • Explore hand-crank generator designs and calculations
  • Study the relationship between power, force, and distance in mechanical systems
DIY enthusiasts, electrical engineers, and anyone involved in building or optimizing generator systems.
bonna
I'am making some calulations on a product that i later will atemte to build, and i was wondering how you calulate the resistance of a generator !? The mechanical resistance, that is how big a force will i need to drive e.g a 6v generator?
All replays welcome
Bonna
The mechanical resistance of a generator changes as the the amount of electricity used changes. If you switch off all appliances, the mechanical resistance of an ideal (frictionless) generator goes to zero. If the thing usung the electricity is at a steady level of demand, the input "work" should remain constant.
Using the law of conservation of energy, you will need to know how many watts of power is being used by the thing you are powering. You will need to put in this many watts of power, plus about 40% more, into the generator (to overcome friction and heat loss). If the generator is a hand-crank, for instance, you can estimate the force required:
power= (force x distance)/ time so:
force = (the number of watts required) times (the time in seconds to turn the crank once)divided by (the circular distance in meters through one turn of the crank).
The force will be in Newtons. divide by 4.4 to get pounds.
