What is the temperature of the gas in state A?
  • Thread starter Thread starter roam
    Thermodynamic
The discussion revolves around determining the temperature of an ideal monoatomic gas in state A after it undergoes a series of thermodynamic processes, including isobaric expansion, isochoric cooling, and isothermal compression. The problem involves applying the ideal gas law and understanding the relationships between pressure, volume, and temperature.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the implications of the gas expanding to three times its initial volume and question how to apply the ideal gas law without knowing the initial volume. There are discussions about converting temperatures and the relationships between the states of the gas.
Some participants suggest using the ideal gas law to relate the temperatures and volumes at different states. There is a recognition that the initial volume does not need to be known to find the temperature at state A, as the ratios can be used instead. Hints about temperature conversion are also provided.
The problem is constrained by the requirement to determine the temperature without complete information about the initial conditions, prompting discussions about assumptions and the use of ratios in the ideal gas law.
roam
I can't aolve the following question:
Two moles of an ideal monoatomic gas trebles its initial volume in an isobaric expansion from state A to state B. The gas is then cooled isochorically to state C and finally compressed isothermally until it returns to state A. The molar gas constant is R = 8.314 J mol–1K–1 and Boltzmann's constant is 1.38 × 10–23 JK–1.
If state B corresponds to a pressure P=8 atm (1 atm = 1.013 × 105 Pa) and temperature T = 552°C, determine the temperature of the gas in state A.
Correct answer= 275.0K
[tex]W=nRT ln \left( \frac{V_i}{V_f} \right)[/tex]
I know that in an isothermal process the energy transfet [tex]Q[/tex] must be equal to the negative of the work done on the gas; [tex]Q=-W[/tex]. So to find the Temprature I must use the equation
I'm told that the amount of gas trebles but I don't know the initial volume of the gas, so I'm not sure if I can use this equation.
Another approach is maybe to find the change in temprature and then add it to the original temprature. So first I convert 552°C to Kelvins; 552+273.15=825.15 K. Then I want to use the equation [tex]Q=mc \Delta T[/tex]. But again I don't have the mass! What should I do? :confused:
Is my method even correct?
The volume at A is 1/3 of that at B. P is the same at A and B. Apply the ideal gas law to find T at A. It has to be 1/3 of the temperature at B.
AM
AM
Hi,
[tex]PV=nRT[/tex]
[tex]\frac{PV}{T}=nR[/tex]
[tex]\frac{P_i V_i}{T_i}=\frac{P_fV_f}{T_f}[/tex]
[tex]\frac{V_i}{T_i}=\frac{V_f}{T_f}[/tex]
[tex]\frac{v_i}{552}=\frac{3(V_i)}{T_f}[/tex]
How am I supposed to evaluate Tf now when I don't know what the initial volume is?
?? Divide by Vi - it disappears. (You don't have to find the initial volume. You just need to know Vf/Vi = 3)
[tex]\frac{T_f}{T_i}=\frac{V_f}{V_i} = 3[/tex]
[tex]T_i = \frac{T_f}{3}[/tex]
Further hint: temperatures have to be converted to...
AM
Thanks a lot. :smile:
  • · Replies 33 ·
