Gravitational Fields and Satellite Motion
The problem involves calculating the orbital period of Mercury based on its mean radius and the known orbital period of Earth. The context is gravitational fields and satellite motion, specifically applying Kepler's laws and gravitational equations.
  • Mixed
  • The original poster attempts to derive the relationship between the orbital periods and radii of Mercury and Earth using gravitational equations. Some participants question the units of the final answer, specifically what the value of 0.24 represents.
Participants are exploring the calculations and conversions necessary to verify the original poster's results. There is a recognition of the importance of units in the final answer, and some guidance is offered regarding the need for clarity in expressing results.
There is mention of a teacher's approach to problem-solving that emphasizes confusion before clarity, which some participants find frustrating. The original poster expresses dissatisfaction with the feedback received on their calculations.
Cilabitaon
The Earth's orbit is of mean radius [tex]1.50*10^{11}m[/tex] and the Earth's year is 365 days long.
The mean radius of orbit of Mercury is [tex]5.79*10^{10}m[/tex]. Calculate the length of Mercury's year.
[tex]F=\frac{mv^{2}}{r}[/tex]
[tex]F=\frac{Gm_{1}m_{2}}{r^{2}}[/tex]
[tex]d=v \cdot t[/tex]
[tex]v = \frac{d}{t} = \frac{2 \pi r}{t}[/tex]
[tex]\frac{mv^{2}}{r} = \frac{Gm_{1}m_{2}}{r^{2}}[/tex]
[tex]v^{2} = \frac{Gm}{r}[/tex]
subbing in [tex]v = \frac{2 \pi r}{t}[/tex] we get
[tex](\frac{2 \pi r }{t})^{2} = \frac{Gm}{r}[/tex]
by expanding;
[tex]\frac{4 \pi^{2}r^{2}}{t^{2}} = \frac{Gm}{r}[/tex]
through rearranging this we can get the formula;
[tex]\frac{r^{3}}{t^{2}} = \frac{Gm}{4 \pi^{2}}[/tex]
and since [tex]\frac{Gm}{4 \pi^{2}}[/tex] is constant for all planets (as m is the mass of the Sun) then we can assume;
[tex]\frac{R_{E}^{3}}{T_{E}^{2}} = {R_{M}^{3}}{T_{M}^{2}}[/tex]
where [tex]R_{E} , T_{E}[/tex] and [tex]R_{M} , T_{M}[/tex] are the radius of orbit and the time period of orbit of Mercury and Earth around the Sun; respectively.
Now, to find [tex]T_{M}[/tex] seems simple enough, as I am given the constants I need.
[tex]T_{M}^{2} = \frac{T_{E}^{2}}{R_{E}^{3}} \cdot R_{M}[/tex]
This gives me an answer of;
[tex]T_{M}^{2} = \frac{(365 * 86400)^{2}}{(1.50*10^{11})^{3}} \cdot (5.79*10^{10})^{3}[/tex]
I then find [tex]T_{M}[/tex] to be [tex]7.564*10^{6}s[/tex]; whereas my teacher seems to think this is wrong, and gave me 2/7 marks for this: he got his answer to 0.24...please help.
He got his answer to be 0.24 what? To see if you are right, look up the orbital period of Mercury (usually given in days) and convert to seconds. It's as easy as that.
Yep, he gets his answer to be 0.24, and no matter what I try I can't seem to get his answer, every conversion just fails for me =[
Can you please tell me, what the units of this 0.24 are?
That's the point, he's so anal about not doing any work for us; he always says "In order to understand the problem you must be utterly baffled beforehand"; so he just says "you should have 0.240" and leaves it at that.
edit:
I am going to kill both myself and my Prof.
The units are years.
[tex]\frac{7.564 \times 10^{6}}{(3600 \times 24 \times 365)} = 0.23985 Earth years[/tex]
I understand your frustration and anger and I think that both feelings are not conducive to learning. However, I think that your teacher is trying to "baffle" you in an inappropriate manner. In my book, any number should be followed by the appropriate units. Conversely, if I ask someone to find a number, if the number is correct and the units are correct, then the answer is correct. I wish you fortitude, humor the guy and this too shall pass.
Or I could just kick his ***.
  • · Replies 30 ·
  • · Replies 16 ·
  • · Replies 17 ·
