Thread Closed
Simple Harmonic Motion, rigid pendulum
Share Thread Thread Tools
Apr5-10, 11:45 PM   #1
A small hole is drilled in a meter stick is to act as a pivot. The meter stick swings in a short arc as a physical pendulum. How far from the center of mass should the pivot point be for a period of 1.65 seconds?
2. Relevant equations
Moment of inertia as given in book: I=(1/3)ml^2
T=2[tex]\pi[/tex][tex]\sqrt{}[/tex]I/mgh
(where t is period, I is moment of inertia, m is mass g is gravity of course, and h is the distance from the pivot oint to the center of mass)
3. The attempt at a solution
I substituted the I in the second equation. The masses cancelled each other out in the square root, l is 1 since it is a meter stick and I used the given T so I end up with the equation...
1.65=2[tex]\pi[/tex][tex]\sqrt{}[/tex]((1/3)/gh)
And then I solved for h getting .493 meters but my book says this is incorrect.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Apr6-10, 12:34 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
The formula you used for the moment of inertia is wrong. The expression you used is for a long rod pivoted at the end, but that's not the case here. You'll want to use the parallel-axis theorem to get the correct expression.
Apr6-10, 12:36 AM   #3
That's really weird because the book has an example with a meter stick and uses that formula for I.
Apr6-10, 01:12 AM   #4
Recognitions:
In the example, the meter stick is probably pivoted at its end. That's not what's happening in this problem, so you can't use that expression for I.
Thread Closed
Thread Tools
Similar Threads for: Simple Harmonic Motion, rigid pendulum
Thread Forum Replies
Simple Harmonic Motion: Pendulum Introductory Physics Homework 1
Simple Harmonic Motion of a Rigid Body Introductory Physics Homework 2
Simple Harmonic Motion of a pendulum Introductory Physics Homework 6
Pendulum in Simple Harmonic Motion Introductory Physics Homework 3
Simple Harmonic Motion of a Pendulum Introductory Physics Homework 4
