Thread Closed
Watt needed to heat up an iron, correct?
Share Thread Thread Tools
Apr6-10, 06:09 AM   #1
an IRON cube with (Length 1.3cm Width 1.3cm Height 0.7cm) so
Volume = 1.183cm^3
density of an IRON = 7.8gm/cm^3 so
Mass = 9.2274gram
Q=mcT c for iron = 0.450 J/(g·K), T difference = 160 degree celsius
Q=9.2 . 0.45 . 160
Q=662.4Joule
1Joule = 1 Watt.second
so if i need to heat up an IRON from 20C to 180C (T difference = 160 degree celsius) in 60second
so i need (662.4/60) = 11.04Watt
correct? please advice..
thanks
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Apr6-10, 07:25 AM   #2
Recognitions:
Homework Helper Homework Help
Yes that should be correct.
Thread Closed
Thread Tools
Similar Threads for: Watt needed to heat up an iron, correct?
Thread Forum Replies
Heat Engine with Finite Heat Capacity- Is my answer correct? Introductory Physics Homework 3
[SOLVED] Quantity of Heat/Specific Heat Water+Iron Introductory Physics Homework 3
The reaction of rusting iron and the heat produced Biology, Chemistry & Other Homework 1
heat turn iron to gold if heated?? Introductory Physics Homework 2
Cast Iron pitting with high heat Materials & Chemical Engineering 1
