Electric Vehicle Battery specification (very basic)
The discussion revolves around the specifications and calculations related to electric vehicle (EV) batteries, particularly focusing on energy requirements, battery configurations, and efficiency. Participants explore theoretical aspects, practical implications, and comparisons with existing EV models.
  • One participant calculates that their concept electric car requires 15,000 Wh to operate over 100 miles and seeks to determine the number of batteries needed based on a motor voltage of 156 vDC.
  • Another participant confirms that for a 20 kW-hr battery at 156 volts, this translates to 128 amp-hours, suggesting that if each battery is rated at 100 amp-hours, the entire pack would also be rated at 100 amp-hours.
  • A participant explains that batteries wired in series increase voltage while those in parallel increase current, and discusses the configuration of batteries in the EV-1 model, which had a higher voltage system but similar energy requirements.
  • There is a recalculation by the original poster who now states a requirement of 15 kWh for 100 miles, questioning the validity of their initial estimate and comparing it to the Aptera 2e's specification of 13 kWh for the same range.
  • Questions are raised about the implications of battery efficiency, particularly whether a 90% efficiency rating limits power output or affects battery life.
Participants express differing views on the energy requirements for electric vehicles, with some suggesting that the original poster's calculations may be too low. There is no consensus on the exact specifications or efficiency impacts, and the discussion remains unresolved regarding the optimal battery configuration and energy estimates.
Participants reference various assumptions, such as the efficiency of batteries and the specific drive cycle characteristics, which may not be fully defined or agreed upon. The calculations depend on the definitions of energy consumption and battery performance metrics.
robinfisichel
I have an concept electric car, i calculated it will need 15,000 Wh stored in batterys to operate over its required range (100 miles) on a certain drive cycle.
I am attempting to work out how many batteries i need
The motor it is powering has a voltage rating of 156 vDC specs here: http://www.azuredynamics.com/products/force-drive/documents/AC24LS_DMOC445ProductSheet.pdf
so does this mean that in Ah this is equivilent to 128 Ah? (P.t=IV.t = 2000 = I.156)
if i were using say, 3.3v batteries would this mean i need 48 (48x3.3=158)?
Also what are the effects of battery efficiency? If i have a 90% efficient battery does that mean my power is limited by 10% or is this just for the battery life?
A typical electric vehicle can get 3 miles per kilowatt-hour, some can get 4 miles per kW-hr. You are designing for 5 miles per kW-hr, which is OK for a small light vehicle. For 156 volts and a 20 kW-hr battery, this is equivalent to 128 amp-hours (at full voltage). If each battery in the series is rated at 100 amp-hrs, then the entire battery pack is rated at 100 amp-hrs.
Bob S
I am not an electrical engineer by any stretch, but I can give you a little insight. First, batteries wired in series add voltages but not current; those wired in parallel add currents but not voltage. Multiple batteries can be wired using a combination of both methods to achieve the necessary combination of voltage/current.
The old EV-1 electric car had similar requirements and range that you are quoting, but used a 312 volt system instead of 156--exactly double. Therefore their motor current would be half of what you would be using, but the overall energy requirement would be the same, as the EV-1 also had a roughly 100 mile range. The EV-1 battey pack is quoted as follows:
"The Panasonic battery pack consisted of twenty-six 12 volt, 60 amp-hour lead-acid batteries holding 67.4 megajoules (18.7 kWh) of energy. The NiMH packs contained twenty-six 13.2 volt, 77 Ah nickel-metal hydride batteries which held 95.1 megajoules (26.4 kWh) of energy." (from Wikipedia).
Doing the math, I would assume that all of their batteries were wired in series to get the required voltage; in your case, you could do 13 (instead of 26), 12 volt/120-140 amp hour batteries in series to get the same overall power at 156 volts instead of 312. (Or, some combination of lower voltage batteries with similar amp hour ratings to get up to the required voltage.)
I hope that helped a little...
Bob S
Thanks Bob, though i recalculated and got 15Kwh for 100 miles now! I really can't see where i am going wrong if people think this is too low though. Drag is ok, rr is ok, force to accelerate is ok (though the drive cycle means accelerations are quite low). I have implemented motor eff but not any other at the moment.
If anyone looks up "Aptera 2e" you will see that it specifys 13,00 kWh for a range of 100 miles!
Thanks, the more info i have on battery alternatives the better.
  • · Replies 63 ·
22K
  • · Replies 117 ·
12K
  • · Replies 30 ·
  • · Replies 26 ·
22K
