Clarification on position equation for simple harmonic motion
The discussion revolves around the position wave equation for simple harmonic motion (SHM), specifically the equation x = Acos(omega*t + delta). Participants pose questions and seek clarifications on various aspects of the equation, including the choice of cosine versus sine, the definitions of terms like width and frequency, the nature of amplitude in idealized versus real systems, and the differentiation between Greek letters used in the context of SHM.
  • Homework-related
  • Some participants question why cosine is used in the wave equation instead of sine, suggesting that sine might be more intuitive since it starts at zero, while others argue that cosine is standard due to its properties.
  • There is a discussion about the term "width," with some participants clarifying that it refers to wavelength, while others note that frequency is a separate concept related to the number of cycles per unit time.
  • Participants express uncertainty about whether amplitude A decreases over time, with some suggesting that SHM is an idealization that does not account for damping, while others affirm that real systems do experience damping.
  • Questions arise about how to differentiate between small and capital Greek letters, with some suggesting that context usually clarifies their meaning.
  • There is a query about the use of different symbols for frequency, with some participants explaining that omega represents angular frequency, while f is the standard frequency, leading to some confusion over their interchangeable use.
  • Some participants confirm and refine earlier claims about the nature of oscillation in SHM, including the relationship between displacement and equilibrium points.
Participants express a mix of agreement and disagreement on several points, particularly regarding the use of cosine versus sine, the nature of amplitude in idealized systems, and the definitions of terms related to frequency and wavelength. The discussion remains unresolved on some of these topics, with multiple competing views presented.
Limitations include varying interpretations of terms like width and frequency, as well as the distinction between idealized and real systems in the context of SHM. The discussion also reflects differing levels of understanding regarding Greek letter notation.
This discussion may be useful for students and enthusiasts of physics and mathematics who are seeking clarification on simple harmonic motion, wave equations, and related terminology.
darryw
I have 4 quick questions about the position wave equation, x = Acos(omega*t + delta), can someone please explain this (in very simple language) thanks!
1. Why do we have to use cos? why not sin? wouldn't sine be better so that amplitude starts at zero also? using cos must make things easier, but i don't see why?
2. Is "width" the distance between any two peaks or troughs of the wave? Is this the same as frequency of wave? (if its now, then what is the correct term for width?)
3. doesn't A gradually decrease over time ( this is obvious from intuition) and if so, then why are the waveforms always drawn with uniform amplitude? (is this just an idealized wave (no friction or damping)? AKA: SIMPLE harmonic motion?
4 how do we differentiate between small greek letters and big? for eg, delta looks totally different when small vs big, so what do we say "small delta" or "capital delta" or what? seems confusing..
thanks for any help
1) I have no idea. One possibility is that Re(exp(i*theta)) is cos(theta) and when you are doing superpositions you can use the identity cosA+cosB=2cos(a+b/2)cos(a-b/2) to add your two waves like thus:
exp(i(A)) + exp(i(B)) = 2exp(i(A+B/2))exp(i(A-B/2)) = 2exp(i(A+B/2)+(A-B/2))
(or something like that)
Also, when you do superpositions, often the greatest amplitude is right at the zero point and gradually lessens as you go further.
(Could someone else chime in on this one?)
2) Yes, but it's called wavelength.
3) Not in simple harmonic motion, since the definition of which is motions with no dampening or 'driving' (thanks wiki).
4) No idea. I think most people would call a capitol delta a delta the same as a lowercase delta.
You don't have to use the cos function ,The sin function can describe the motion also. The use of cos is more standard because cos(0)=1 which makes a lots of things cleaner.
It is called wavelength. Note that SHM is not the description of a wave just of an oscillator.Frequency is a measure of how many complete cycles the oscillator has made in a set unit of time .
SHM is an idealization. In reality there is always some damping. You study SHM first because it is easy and useful.if you take a more advanced class in waves you will study the effects of damping.
darryw said:
4 how do we differentiate between small greek letters and big? for eg, delta looks totally different when small vs big, so what do we say "small delta" or "capital delta" or what? seems confusing..thanks for any help
Small deltas are used for partial derivatives. Capital Deltas are used to express small nonzero changes or displacements. Nobody really says delta. you just write it down and expect everyone to Know what you want to say.
Thanks for replies.. just have another question about the correct symbol for frequency:
textbook says frequency of a spring is omega = root k/m.
but then it says frequency is the inverse of the period, written like this: f = 1/T
please explain why they use both symbols to mean frequency?? thanks
Omega is the angular frequency. it represents how many complete rotation cycles your vector has made per unit time. [tex]\omega=2\pi\cdot f[/tex]
[tex]\ T=1/f[/tex]
Look here for more details
http://hyperphysics.phy-astr.gsu.edu/HBASE/hframe.html
"doesnt A gradually decrease over time ( this is obvious from intuition) and if so, then why are the waveforms always drawn with uniform amplitude? (is this just an idealized wave (no friction or damping)? AKA: SIMPLE harmonic motion?'
The answer given above is correct...if you want a gradually decreasing amplitude, one uses a term like
e-t or 1/t as an example...
Is all of this correct (this is in my own words):
In SHM graph of an oscillating spring, when the y-axis is positive the spring is stretching beyond its EQ point.
The EQ point is where the spring comes to rest with no forces acting on it .
When y-axis is negative, the spring is compressing.
Amplitude represents the spring's max and min displacement from the EQ point.
It is convention to set t=0 at the waveforms max amplitude, this is why we use cosine in the position equation.
Yup, that's right.
One thing tho, it doesn't matter (mathematically, in this case) if you consider the spring stretching or compressing at the positive y-axis. But you have the idea.
Yes.
The mass on the spring is not at rest at the equilibrium. Only the accelerations is 0.
Yes but this is due to the choice of coordinates.
Yes.
9K
  • · Replies 51 ·
  • · Replies 17 ·
