Radius of curvature of a function
The discussion revolves around finding the radius of curvature for the function y=lg(x) or y=√x, particularly in the context of analyzing bending stress in a beam between two points x1 and x2.
  • The original poster attempts to determine the radius of curvature using various methods, including arc length and a formula involving yield stress. Some participants suggest a simpler formula for radius of curvature, while others question whether to use an average or maximum curvature between the specified points.
Participants are exploring different interpretations of how to calculate the radius of curvature and its implications for the engineering problem at hand. There is acknowledgment of the potential for simplification in the approach, but no explicit consensus has been reached on the best method to use.
The original poster notes a shift in focus to analyzing the beam at different sections, indicating a need for clarity on how to apply the curvature formula across various x points.
rock.freak667
I have a graph of y=lg(x) which is supposed to mimic the curvature of a beam, or I can use y =√x to be more precise. But in essence between two points x2 and x1, I need to find the radius of curvature R so as to find the bending stress on it.
I don't know if it is as simple as taking the arc length and dividing by π or something. Any help would be fine.
Or could I use
E/R = σ/y
and use σ as the yield stress and get R from there, though that is assuming that it is a straight beam.
Dick said:
You are making this too complicated. If you have y=f(x) there's a reasonably simple formula for radius of curvature. See formula 5 in http://mathworld.wolfram.com/RadiusofCurvature.html
:smile: oh my, I've seen that equation all my life and I've been using it to find radius, add in the word curvature and I complicate life. Thanks for lessening my work load!
Would it be best to use the average of x1 and x2 and get the curvature then?
Not sure. I don't know the engineering problem. Do you want an average between x1 and x2, or a max between x1 and x2 or something else? What's best depends on the problem.
If I could I'd like to get an average estimate for the entire length from x=1 to some x=x2
EDIT: nvm, I am analyzing the beam at different sections, so those are at certain x points, so I can just reuse the formula throughout. Thank you again.
  • · Replies 18 ·
  • · Replies 20 ·
  • · Replies 18 ·
