How to Secure PCBs in a Stratospheric Balloon's Electronics Box?
The discussion focuses on securing printed circuit boards (PCBs) within an electronics box designed for stratospheric balloon flights. A proposed solution involves using screw standoffs to stack the PCBs, ensuring a robust connection while minimizing weight. Participants suggest utilizing diecast boxes with PCB guides available from standard electronics suppliers, while also recommending shock-absorbing mounts for added protection against environmental stresses during flight.
  • Understanding of PCB design and mounting techniques
  • Familiarity with diecast enclosures for electronics
  • Knowledge of shock-absorbing materials and their applications
  • Experience with custom machining processes for electronic components
  • Research diecast boxes with integrated PCB guides from electronics suppliers
  • Explore the use of screw standoffs for PCB stacking and mounting
  • Investigate various shock-absorbing materials suitable for electronics protection
  • Learn about custom machining options for creating tailored PCB mounts
Electronics engineers, aerospace designers, and hobbyists involved in developing ruggedized electronic systems for high-altitude applications.
kmail
Hello
I'm designing a box for 6 PCBs. It will fly on stratospheric balloon. Do you know a solution of mounting PCBs to box walls, which will provide strong and stable connection? I was thinking about slots in internal walls, but that can be not enough.
I found interesting solution:
http://img94.imageshack.us/img94/7586/dsc9131.th.jpg
Do you know something more about that type of mounting? Where can I get these parts, which hold PCBs?
That looks like it was custom machined.
You can get regular diecast boxes with pcb guides from the normal electroncs supplies.
But - if you are concerned about weight and ruggedness more than easy servicing I would probably connect all the boards together in a stack with screw standoffs between them and then put them in a box on some sort of foam/rubber/shock-absorbing mount
  • · Replies 21 ·
  • · Replies 26 ·
9K
