Calculating Deceleration Forces: Is It Easier to Use g's or Mass?
  • Context: High School
  • Thread starter Thread starter wirenut67
    Deceleration Force
The discussion revolves around calculating the force experienced by a person in a vehicle during deceleration, specifically from 12 mph to 8 mph over 0.5 seconds. Participants explore the appropriate units and methods for calculating mass and force, including the use of slugs and g's.
  • One participant proposes a method for calculating deceleration using the formula for initial and final velocities.
  • Another participant points out the need to convert units from mph to ft/sec and clarifies the distinction between weight and mass in the British system.
  • There are questions about the conversion of mass from pounds to slugs, with some participants expressing confusion over the relationship between these units.
  • Participants discuss the calculation of deceleration and its representation in ft/s², with corrections made regarding the proper units for acceleration.
  • One participant suggests that expressing deceleration in g's may simplify the calculation of force, proposing an alternative method to arrive at the same result.
While there is some agreement on the calculations and methods used, multiple competing views remain regarding the preferred units (slugs vs. g's) and the clarity of the conversion process. The discussion does not reach a consensus on the best approach to take.
Participants express uncertainty about unit conversions and the implications of using different systems of measurement. There are unresolved questions about the clarity of the relationship between weight and mass in the context of the calculations.
This discussion may be useful for individuals interested in physics, engineering, or anyone looking to understand the principles of force and deceleration in vehicle dynamics.
wirenut67
Greetings,
First post here.
I am trying to calculate the force applied to a 150 lb. person riding in a vehicle that decelerates from 12mph to 8 mph in .5 seconds.
If I am understanding correctly the formula is:
Initial velocity-Final Velocity/.5
So
12-8/.5 = 8
The to calculate the force,
m x d = f
so mass is 150 lbs
Deceleration is 8
so force is 1200 Lbs?
This does not seem correct to me, any help would be appreciated.
Thanks!
Mike
You are trying to apply Newton's 2nd law (F = ma), but you are messing up the units.
Use standard units for velocity: ft/sec, not mph.
Mass is 150/32 slugs, not 150 lbs.
Are you telling me that mass will be 150 LBS divided by 32 slugs?
This is the part I am not understanding.
This is why I always convert to metric before I do these calculations. I try to avoid any equation with the word "slug" in it like the plague.
No. The mass is measured in slugs. (32 is the acceleration due to gravity in ft/s^2.)
In the British system of units, mass is measured in slugs. The weight (force) is related to the mass via weight = mg, where g is the acceleration due to gravity. In that system of units, g = 32 ft/s^2 (approximately).
Ok so for the first part I would use:
Initial Velocity= 17.6 ft/s (12mph)
Final Velocity = 11.7 ft/s (8mph)
Deceleration time = .5 seconds
So then
17.6-11.7= 5.9 ft/s
5.9ft/s /.5 seconds = 11.8 ft/s
Is this correct for the first part of the calculation?
So then
17.6-11.7= 5.9 ft/s
Yes. (But the units for acceleration are ft/s², not ft/s.)
So the final result would be 11.8 Ft/s²?
Al I really appreciate your patience here. This is just something I am beginning to understand.
Mike
So written correctly it should be:
17.6 ft/s²-11.7ft/s²= 5.9ft/s²
and then
5.9 ft/s² /.5= 11.8 ft/s²
Is this correct Sir?
Yes.
The units for speed would be ft/s, not ft/s².
and then
5.9 ft/s /.5 s = 11.8 ft/s²
Doc Al said:
Yes.
Understood so far.
So my rate of deceleration is 11.8 ft/s²
So now I move to force.
Force= mass x deceleration.
Is this correct Al?
So my deceleration is 11.8ft/s²
Where I am lost is in figuring the mass based on slugs. Can you show me how to do this?
wirenut67 said:
Understood so far.
Is this correct Al?
All good.
Weight = mass X g(acceleration due to gravity)
so:
mass = Weight/g(acceleration due to gravity)
Here we measure weight in pounds, g is 32 ft/s², and the mass is in slugs. So:
mass = [150 lbs]/[32 ft/s²] =
mass = [150 lbs]/[32 ft/s²] =4.6875 slugs?
So then
4.6875 slugs x 11.8 ft/s ^2 is a force of 55.31 slugs or 55.31 lbs of force?
wirenut67 said:
So then
4.6875 slugs x 11.8 ft/s ^2 is a force of 55.31 [STRIKE]slugs[/STRIKE] or 55.31 lbs of force?
The force will be in pounds, not slugs. (The mass was in slugs.)
So the final result is that the force is 55.31 lbs of force?
Right. That's the average force for the given acceleration.
Al could I bother you for just a second to review this for me.
I am posting this written like this so please look this over for me.
We can calculate the force created by braking from 12mph to 8 mph in .5 seconds, and its force upon a 150lb human.
To calculate the deceleration rate we take this formula:
Initial Velocity - Final Velocity / time = deceleration rate.
First we convert mph to ft/s:
12mph is 17.6 ft/s
8mph is 11.7 ft/s
Braking time is .5 seconds
So
17.6 ft/s - 11.7 ft/s = 5.9 ft/s
then
5.9 ft/s / .5 seconds (time) = 11.8ft/s²
Now we can figure force.
Force = mass x deceleration
deceleration as defined above = 11.8 ft/s²
Mass has to be converted to slugs
A slug is weight/g (acceleration due to gravity)
So
150lbs/32 ft/s²= 4.6875 slugs. This is the mass in slugs based of deceleration due to gravity.
So
Mass= 4.6875
Deceleration = 11.8ft/s²
11.8ft/s² (deceleration) x 4.6875 (mass)= 55.31 pounds of force.If this is correct than you have done a fantastic job for me AL and it is much appreciated. I thank you for your patience.Mike
Looks good to me!
Doc Al said:
Looks good to me!
Again Al many thanks!
In your opinion would this amount of force create a noticeable reaction from the vehicle occupants?
It's 1/3 their weight, so it's noticeable. (No big deal, though.)
Agreed and Thanks Again Al!
Wouldn't it be easier to state the decel rate in g's, then multiply the mass by that to get the force?
11.8 ft/sec^2/32 ft/sec^2 = 0.369 g
0.369 g x 150 lbs = 55.3 lbs
Same thing but in a different order; makes more sense to me because I deal with g's rather than slugs.
  • · Replies 46 ·
13K
  • · Replies 16 ·
  • · Replies 29 ·
  • · Replies 23 ·
  • · Replies 29 ·
  • · Replies 35 ·
