Evaluating Logarithmic Integral with Cosine and Sine Integrals
  • Context: Graduate
  • Thread starter Thread starter pseudogenius
    Integral Logarithmic
The discussion focuses on evaluating the integral \(\int\frac{dx}{\ln x}\) using complex analysis techniques, specifically through the substitution \(x=e^{i\theta}\). This leads to the expression \(\int\frac{\cos \theta}{\theta} \ d\theta+i\int\frac{\sin \theta}{\theta} \ d\theta\), which results in the cosine integral \(Ci(\theta)\) and sine integral \(Si(\theta)\). The final expression for the integral is given as \(\int\frac{dx}{\ln x}=Ci(-i\ln x)+i \ Si(-i\ln x)\). The discussion also references an identity from Mathematica involving the logarithmic integral \(li(z)\) and emphasizes the importance of considering singularities and limits in contour integration.
  • Complex analysis fundamentals
  • Understanding of contour integration
  • Familiarity with cosine and sine integrals (Ci and Si)
  • Knowledge of logarithmic integrals (li(x))
  • Study the properties of cosine and sine integrals (Ci and Si)
  • Learn about contour integration techniques in complex analysis
  • Explore the logarithmic integral function and its applications
  • Investigate singularities in integrals and their implications on evaluation
Mathematicians, students of complex analysis, and anyone interested in advanced integral evaluation techniques.
pseudogenius
I was trying to evaluate this integral,
[tex]\int\frac{dx}{\ln x}[/tex]
I substituted [tex]x=e^{i\theta}[/tex] and I get,
[tex]\int\frac{e^{i\theta}}{\theta}d\theta[/tex]
which is,
[tex]\int\frac{\cos \theta}{\theta}+i\frac{\sin \theta}{\theta} \ d\theta[/tex]
[tex]\int\frac{\cos \theta}{\theta} \ d\theta+i\int\frac{\sin \theta}{\theta} \ d\theta[/tex]
[tex]Ci(\theta)+i \ Si(\theta)[/tex]
[tex]Ci(\theta)[/tex] and [tex]Si(\theta)[/tex] are the cosine and sine integrals, respectively.
therefore,
[tex]\int\frac{dx}{\ln x}=Ci(-i\ln x)+i \ Si(-i\ln x)[/tex]
I was just asking if anybody has seen the logarithmic integral( [tex]li(x)[/tex] ) expressed this way.
Interesting. The Mathematica functions site (http://functions.wolfram.com/GammaBetaErf/LogIntegral/27/01/0003/) lists the following identity:
[tex]\text{li}(z)=\text{Ci}(i \log (z))-i\text{ Si}(i \log (z))-\log (i<br /> \log (z))+\frac{1}{2} \left(\log (\log (z))-\log<br /> \left(\frac{1}{\log (z)}\right)\right)[/tex]
This contains your two terms but has some added terms. I'm not sure why.
Pay attention to limits of integration.
Your first integral is from 0 to x, but your substitution means that your second integral is now a contour integral over from [itex]-i \ln{x}[/itex] to [itex]i\infty[/itex]. So, you can't use cosine and sine integrals already. An added difficulty is that 1/ln(x) has a singularity at x=1, and, consequently, [itex]e^{i\theta}/{\theta}[/itex] has a singularity at 0. You need to think how to do the contour integral so that the result matches the Cauchy principal value of your original integral.
  • · Replies 29 ·
