| Thread Closed |
Uniform plank - Supporting force |
Share Thread | Thread Tools |
| Apr11-10, 06:07 PM | #1 |
A uniform plank is supported by two equal 120 N forces at X and Y. The support at X is then moved to Z (halfway to the plank center). The supporting force at Y then becomes? _____________________________ X...........Z...........c......................Y i tried to draw it above. The line is the plank, X and Y are the supports, Z is where X is moved to, and (c) is the center of the plank 3. The attempt at a solution I came across this as i am studying for my test and i am a little lost. The solution says to do this: (240 N)(1/4L) = Fy(3/4L) and the answer is 80 N I am confused on where this solution comes from. Any explaining would be very helpful :) Thank you |
| Apr11-10, 07:16 PM | #2 |
Recognitions:
Well start off with X and Y being at the ends. If the system is in equilibrium there, what should be the force acting at the center c?
| Apr11-10, 07:16 PM | #3 |
you are given the initial reactions; what must be the weight of the plank, and at what point does the resultant force of the plank's weight act?
| Apr11-10, 07:51 PM | #4 |
The force at the center would be (120N + 120N) = 240N correct?
Is the equation used for this dealing with torque? thanks for the help |
| Apr11-10, 08:17 PM | #5 |
Recognitions:
| Apr11-10, 08:31 PM | #6 |
I dont have the distance so i believe the plank length is considered L.
I am not sure what you mean by moment. When you say moment do you mean Moment of force = Torque:[itex]\mathbf{\tau}= \mathbf{r} \times \mathbf{F}[/itex] |
| Apr11-10, 08:41 PM | #7 |
the terms torque, moment, or moment of a force, are often used interchangeably.
| Apr11-10, 08:56 PM | #8 |
Oh ok thanks for the insight on that :)
does this seem right. if i take the torque about point Z then tcenter + ty = tz (240N)(1/4L) + (Fy)(3/4L) = 0 |
| Apr11-10, 08:57 PM | #9 |
Recognitions:
| Apr11-10, 09:41 PM | #10 |
Ok thank you :)
| Thread Closed |
| Thread Tools | |
Similar Threads for: Uniform plank - Supporting force
| As level Non-Uniform Plank question. | Introductory Physics Homework | 7 | ||
| Uniform background dust of plank mass black holes. | Special & General Relativity | 4 | ||
| A uniform Plank | Introductory Physics Homework | 1 | ||
| Period of uniform plank with spring not at Center of Mass | Introductory Physics Homework | 7 | ||
| period of a uniform plank with a spring | Introductory Physics Homework | 15 | ||
