Differential Equation dont understand t>0 how to apply that to equation
The discussion revolves around a first-order linear differential equation of the form y' + (2/t)y = cos(t) / t^2, with an initial condition y(pi) = 0 and the constraint that t > 0. Participants are exploring the implications of the initial condition and the significance of the domain restriction.
  • Participants discuss the process of isolating y and whether constants should be divided by t^2. Questions arise about the meaning of the condition t > 0 and its relevance to the solution. There is also confusion regarding the application of the initial condition in the context of the differential equation's domain.
Some participants have provided insights into the nature of the solution and the implications of the initial condition. There is an ongoing exploration of how to correctly interpret the equation under the constraint t > 0, with various interpretations being considered.
Participants note that the differential equation is undefined at t = 0, which raises questions about the behavior of the solution as t approaches zero and the necessity of the condition t > 0.
darryw
y' + (2/t)y = cos(t) / t^2 initial cond: y(pi) = 0 ... t>0
integrating factor is t^2
so.. integ (yt^2)' = integ cos (t)
= yt^2 = -sin (t) + c
y = ( -sin (t) /t^2 ) + c
..this brings up my first question.. when i divided through by t^2 to isolate y, am i correct in saying that I don't need to also divide c by t^2, because a constant divided by a constant is still just another constant.. right?
so .. with that assumption...
0 = ( - sin (pi) / pi^2 )+ c
0 = ( - 0 / pi^2 ) + c
0 = c
this where I am stuck, because i realize IC said that t>0.. but what does it mean to apply that IC to the equation?? Does this lead to an actual value for c somehow? thanks
edit: if it says that t = pi .. that is, y(pi) = 0 .. then why would it also say t>0 ?? pi is clearly bigger than zero, so why the added condition?
Mistake in the line above.
No, you are not correct. You need to divide c by t^2 -- t^2 is not a constant.
0 = c
Because the diff. equation is undefined for t = 0.
thanks for reply.
yt^2 = sin(t) + c
y = sin(t) / t^2 + c/t^2
IC: y(pi) = 0
0 = 0 / pi^2 + c/pi^2
c = 0(pi^2)
c = 0
i understand why it is undefined at zero but I am not grasping how to apply that info to solve the equation. thanks for any more help
darryw said:
thanks for reply.
yt^2 = sin(t) + c
IC: y(pi) = 0
c = 0(pi^2)
c = 0
You don't need to apply the information that t > 0. And you almost there with the solution.
You have y = sin(t) / t^2 + c/t^2 and c = 0, so y = ?
if t = 0 then i can cancel last term
y = sin(t) / t^2
that is the solution to the problem?
No, t can't be zero.
You have y(t) = sin(t) / t^2 + C/t^2 and y(pi) = 0, so
0 = y(pi) = sin(pi)/t^2 + C/t^2
==> C/t^2 = 0 ==> C = 0
So y(t) = sin(t) / t^2, and we still have the restriction that t > 0.
y = sin(t) / t^2
You mean "if c= 0". And you should include "t> 0" in your solution:
y= sin(t)/t^2, t> 0.
Since the differential equation does not hold at 0, not only can t not be 0 but you cannot continue the solution to negative values of t.
