New Reply
What are everyday ``nonlinear" examples?
Share Thread Thread Tools
Apr12-10, 06:54 PM   #1
Hello!
Is there a simple way to identify a nonlinear equation or physical system by looking at it?
I have sifted through material about unpredictability, chaos, fractals, and the other buzzwords encompassing ``nonlinear systems", and have glossed over mathematical explanations covered in Wiki articles, but do not seem to understand how to identify an algebraic nonlinear example other than ``variable cannot be separated", ``superimposed," is "non-homogenous". I am seeking a basic explanation for rather young kids in a gifted physics program.
For example, is an exponential, logarithm, root, or quadratic nonlinear as they do not conform to ``lines"? (Notwithstanding that I can just plot it against two logs to get a line.) And also, the above examples are ``predictable," no? Are they still nonlinear?
Does nonlinearity imply that despite knowing the initial conditions the outcome cannot be predicted?
(I solved the intersection of a quadratic and a linear equation, found two points, and am concluding the system is ``nonlinear" because the ``nonlinear" shape of x^2 (parabolic) causes the equation to be a ``system" of solutions (more than one point satisfies the bounds).
I am seeking an elementary school explanation and basic examples.
Thanks,
-E
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Apr12-10, 07:12 PM   #2
Recognitions:
Homework Helper Homework Help
In my mind most things are nonlinear. Treating things (within a fixed range) as though they were linear is a mathematical trick that lets us work with complicated things as if they were simple.
Quote by UseAsDirected View Post
Your examples are all simple, predictable, and nonlinear.
No, that's "chaotic", not "nonlinear". But multivariate nonlinear systems are often chaotic.
Apr12-10, 09:12 PM   #3
Thank you for the response. I get it now that nonlinear systems can be simple and deterministic.
And, does ``sensitivity" to initial conditions imply chaos? I read about these buzzwords and that due to such and such sensitivity hither tither system is ``chaotic" or not-deterministic. Do I conflate the two, chaos and non-determinism? I am trying to build up a catalog of understanding. Thanks again.
-E
Apr13-10, 01:19 AM   #4
-E
No, sensitivity to initial conditions is not enough for chaos. To have chaos, you also need to visit every point in the phase space arbitrarily closely an infinite number of times, at any large time frame (this is just a rough explanation; to really define chaos you need to get nitty gritty with higher mathematics). What does this mean? Consider the function x^n as n goes to infinity. This function is sensitive to initial conditions, since starting with 1 it will just give 1, but start at any number greater than 1, say 1.000000000001, and it will give infinity. So it's really sensitive to initial conditions. But it's not chaotic; it's simple and predictable.
The logistic map is a really simple (and good) introduction to chaos, you might want to read about it if you haven't already: http://en.wikipedia.org/wiki/Logistic_map
And non-determinism doesn't imply chaos either. A random (not pseudorandom!) sequence of numbers is non-deterministic, but non-chaotic.
Apr13-10, 01:23 AM   #5
Mentor
The Mandelbrot set is determined by a very simple nonlinear equation: z = z2 + c, where z and c are complex numbers. I might be wrong, but I think that the Mandelbrot set is deterministic in the sense that given a complex number you can determine whether it is in the set or not, but very small changes in input values lead to very different outcomes, so the set is very sensitive to changes in initial conditions, hence chaotic. There's a nice animation about halfway down the page at http://en.wikipedia.org/wiki/Mandelbrot_set, in the section titled Zoom animation.
Another example of a simple, non-linear equation with chaotic behavior is in the Bifurcation topic here http://mathworld.wolfram.com/Bifurcation.html. The graph is generated by various values of r in the equation xn = rxn - 1(1 - xn - 1). If you look at the graph, the two left-most red lines are at r = 3.44 and x = .44, x = .85. Substituting .44 for x0 in the equation above gives x1 = 3.44*.44*(1 - .44) ~ .85. Substituting this value in the equation gives x1 = 3.44*.85(1 - .85) ~ .44. Varying r by a little bit causes a small variation in the output values, but varying r by a little more causes bifurcations at around r = 3.45, and more at around 3.545, but the system really goes bonkers at r = 3.57 or so.
Apr13-10, 10:37 AM   #6
Here's a way to think about it: suppose you're measuring the population of bunnies. You know that right now there are 100 bunnies and that the population is growing at the rate of four bunnies per week. If this data allows you to determine the population at all future times, the system is linear. Otherwise, it's nonlinear.
More generally, a system is linear if and only if knowledge of the function and its derivative at any point allows you to completely determine the function.
Apr13-10, 02:13 PM   #7
Mentor
Quote by zhentil View Post
I think you are confusing linear with deterministic. The population growth of rabbits is NOT linear.
Apr13-10, 07:54 PM   #8
Thanks for the responses.
To Ittybitty; hi, you wrote:
>This function is sensitive to initial conditions, since starting with 1 it will just give 1, but start >at any number greater than 1, say 1.000000000001, and it will give infinity. So it's really >sensitive to initial conditions. But it's not chaotic; it's simple and predictable.
What is ``sensitive" about it? I raised a larger number, 1.00001 to 50 and is 1.0005, 1.00001^500 = 1.005, and 1.00001^5,000 = 1.051.
It doesn't seem sensitive at all.
I have another, perhaps more pragmatic physics education questions.
Q.) Are their key *science* concepts to non-linearity? Or, is it just mathematics?
Thanks,
-E
Apr13-10, 08:09 PM   #9
Recognitions:
Here's an example of a reasonably chaotic (though deterministic) system I worked with a few years back.
Take a starting value, say 1. Repeatedly apply the tangent function until it is in a given range, say [319, 320).
Apr13-10, 08:15 PM   #10
Quote by CRGreathouse View Post
I just did it in Excel and it's quite cool!
So, it is chaotic yet ordered?
Apr13-10, 08:37 PM   #11
Mentor
Ittybitty said x^n as n goes to infinity. 50, 500, and 5000 are insignificantly small in comparison to infinity.
Thanks,
-E
Apr13-10, 09:41 PM   #12
Ok, first of all, every single one of you (Mark44, zhentil, UseAsDirected) are making the same, very grave, mistake: assuming that determinism and chaos are incompatible.
In fact, one of the defining marks of chaos is that it has to be deterministic.
let me repeat:
chaos is always deterministic.
In fact, that's why we call it deterministic chaos.
Non-deterministic 'chaos' is just randomness. And randomness is not chaos, it's just randomness. Like the throw of a dice or what age you will die at.
This is actually a common misconception.
Now another misconception is about linear vs. nonlinear systems. The problem arises from the fact that 'linear' is typically taken to loosely mean 'easy' in engineering courses. The word 'linear' does not have a mathematical definition (perhaps the closest thing to mathematical definition would be that a linear system is something that satisfies the superposition principle), but things like 'linear transforms on vector spaces' or 'systems of linear equations' do. Thus it is wrong, in my opinion, to make sweeping assertions about something being 'linear' or not; we have to study the concept in the context it is meant to be studied.
Yup.
Apr13-10, 09:57 PM   #13
Quote by IttyBittyBit View Post
In this example, throwing of die is random? I think the fall of die is calculable, provided all the minutest details are known.
And, what is the relationship between ``determinism" and ``predictability"?
Thanks,
-E
Apr14-10, 12:10 AM   #14
Well it is possible for something to be deterministic, yet not possible for us to be able to predict it. In chaos, usually you have this process where, as you progress forwards in time, the exact details of the initial conditions become more and more important. Take the weather for example (a chaotic process). We have the equations to model it, it's just that we can never know all the initial conditions with 100% accuracy. Thus our prediction ability is limited to just a few days in the future. We can never hope to track every single child across the world blowing bubbles into the wind, for example.
You know about the butterfly effect right? That a single butterfly, flapping it's wings in, say, china, can lead to the difference between a hurricane striking or not striking a city on the coast of the US. The interesting thing about chaos is that this is guaranteed to happen; a flap of a butterfly's wings will, without a doubt, be translated into a storm being created or not.
But with randomness, the picture is different. If something is truly random, we can't even predict it on the shortest time-scale.
You are right, throwing a dice is not in fact random. It's actually very hard to construct a perfectly random sequence. Some people have done this with quantum devices, but even those are based upon the assumption that the quantum world is truly random, something that has not been proven.
Apr14-10, 02:39 AM   #15
The butterfly's act of flapping is guaranteed to create a storm or not? Is ``or not" part a typo? Has it been shown experimentally that a butterfly's flapping guarantees the initiation of a storm? If we cannot micro-analyse the initial conditions of a system, how can we possibly demonstrate this?
I still wonder about this pragmatic issue:
Q.) What is the key scientific concept in non-linearity[, if there is one]? Or, does it belong to mathematics?
Thanks,
-E
Apr14-10, 04:16 AM   #16
-E
No it's not a typo, I just explained it really badly.
What I meant to say is: To model the state of a system as it evolves in time, we eventually need to know finer and finer details about the initial conditions, with no limit to how far we have to go.
This has been proven with a mathematical analysis of the subject of chaos, btw. In fact, it is one of the defining characteristics of chaos. A system that 'forgives' perturbations in the initial conditions smaller than a certain threshold is not deemed chaotic.
About linear/nonlinear systems: you might want to start with researching the superposition principle.
Apr14-10, 05:06 AM   #17
Recognitions:
Gold Membership Gold Member
The questions really are several, I will divide my answers.
Although to CRGreathouse's mind most things are nonlinear to my mind enough things are linear enough for linearity to be useful and essential. That is if they are a bit nonlinear, e.g. if the restoring force in an oscillation curves a bit you can still treat it acceptably depending on accuracy required as linear and get useful results. The concepts are still useful. The qualitative behaviour carries over. For instance even the simple pendulum never has a linear restoring force, it depends on sine of displacement not displacement. Nevertheless even when not quite right the period is still independent, exactly or approximately I don't remember, of maximum or initial displacement i.e. also amplitude. Therefore this is not essentially nonlinear. It is linear for small displacements still.
'Nonlinear science' - think its practitioners think this way - is when you have essentially qualitatively different behaviour from the linear. Thus the nonlinear version of the simple pendulum would be the grandfather clock. Its final period and trajectory or amplitude is independent of initial displacement - called a 'limit cycle'. That is a qualitative difference between the two dynamics.
New Reply
Tags
chaos, nonlinear, prediction
Thread Tools
Similar Threads for: What are everyday ``nonlinear" examples?
Thread Forum Replies
What is meant by "waveform". Working in strogatz nonlinear dynamics, global bifurcati Calculus & Beyond Homework 0
Nonlinear ODE's versus "Statistics". Academic Guidance 0
General & Special Relativity, Everyday Examples Special & General Relativity 13
"examples for proof" General Math 13
third-order hyperpolarizability "γ" in nonlinear optics Atomic, Solid State, Comp. Physics 1
