Difference Between Energy, Power & Work: Explained
  • Thread starter Thread starter imortaltoad
    Energy Power Work
The discussion revolves around the concepts of energy, power, and work, specifically in the context of a slide and ramps with friction. Participants are exploring the relationships between gravitational potential energy and kinetic energy as well as the impact of friction on work done in lifting objects.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants are questioning the relationship between height, potential energy, and the work required to lift objects in different scenarios. They are also discussing how friction affects the work done when moving objects along ramps.
Some participants have provided clarifications regarding the conservation of energy and the effects of friction, suggesting that while potential energy remains constant, the work done against friction varies based on the ramp's angle and distance. The conversation indicates a productive exploration of these concepts without reaching a definitive conclusion.
Participants are considering the effects of friction and the geometry of the ramps, which may influence their understanding of work and energy in this context. There are assumptions about the mass of the objects and the consistency of the gravitational potential energy that are being discussed.
imortaltoad
okay, so what is the difference between these two situations. I don't really seem to get it
http://img190.yfrog.com/img190/8400/2sit.jpg
For the slide, shouldn't the distance be shorter since the slide gets steeper meaning the speed increases !
When the person is at the top of the slide they have lots of gravitational potential energy, but no kinetic energy (they aren't moving). As they begin to slide down, that gravitational potential energy is converted into kinetic energy. Remember that K=1/2mv^2. Since the height of the slide does not change, our potential energy is the same in both cases, which means that our kinetic energy must also be the same. Assuming it is the same person sliding down the slide, and that they didn't just go pig out at the buffet, their mass is also the same. According to our equation, if the kinetic energy is the same, the mass is the same, then the speed at which the slider leaves the slide must be the same.
okay I understand that, but what confuses me is that the situation on the top, with box A and B.
I mean here the height is identical so it means Potential energy should be the same at the top. so shouldn't it require equal amount of work to gain the same amount of potential energy?
In 9.), there is friction between the block and the ramp, so in addition to doing work on the box to increase its potential energy, work has to be done to move the box against the force of friction. The work done to move the box vertically to increase its potential energy is the same for both cases: they are both lifted h distance. However, the friction force acts against moving the block across the ramps surface, and is equal to the coefficient of friction times the normal force (Ffric = mu*N). When the angle of inclination decreases, the normal force N on the block by the ramp increases (N=mgcos(theta)), and therefore the friction force increases. The work done on the block by the friction force is Work = mu*N*X, where X is the distance moved across the ramp. Since the second ramp has a longer distance for the block to move across to reach the same height, the friction force acts for a longer distance, and more work has to be done on the block to reach the top.
Ooohhhhh alright! Thanks a lot=) both posts helped
  • · Replies 0 ·
  • · Replies 58 ·
  • · Replies 35 ·
