How can I calculate torque and force on a rigid body with an offset axis?
  • Context: Undergrad
  • Thread starter Thread starter log0
    Applied Torque
The discussion revolves around calculating torque and force on a rigid body when the axis of torque does not pass through the center of mass. Participants explore the implications of this scenario, including the application of the parallel axis theorem and the behavior of forces and torques in such configurations.
  • One participant seeks clarification on calculating torque and force at the center of mass, referencing a specific example involving an engine axis not aligned with the center of mass.
  • The same participant proposes an equation for torque that appears to involve the parallel axis theorem, questioning its correctness.
  • Another participant suggests that if "torque" refers to a pure moment, it does not have a specific point of application, which may affect the calculations.
  • A further participant discusses the relationship between the reaction torque and the placement of the engine, indicating that the reaction torque does not depend on engine placement but is opposite to the engine torque.
  • Mathematical expressions are shared, including the derivation of torque and force relationships, with some participants affirming the correctness of these derivations.
Participants express varying interpretations of how torque and force relate to the center of mass and the implications of using the parallel axis theorem. There is no clear consensus on the correctness of the proposed equations or the implications of the torque's point of application.
Some assumptions regarding the definitions of torque and force may not be explicitly stated, and the discussion includes unresolved mathematical steps related to the derivations presented.
log0
Hi, I am a noob to physics trying to get a better understanding of rigid bodies.
How do I calculate the torque, force at the center of mass of a rigid body given a torque whose axis is not going through the center of mass of the body?
Example(engine axis doesn't go trough com):
[URL]http://www.piercy.co.za/images/seawind3views1.jpg[/URL]
I found the following equation for the torque:
Tcom = I / (I + m * (r * r)) * T
I is the scalar inertia relative to torque axis n:
n = T / |T|
I = (Inertia * n) * n
I looks like the parallel axis theorem is used here. Is it correct?
And how do I calculate the force due to torque:
Fcom = r x T ?
Welcome to PF!
Hi log0! Welcome to PF! :wink:
If by "torque" you mean a pure moment (a couple ), then (unlike a force) it has no point of application.
It's the same about any point. :smile:
You mean the reaction torque that rotates the fuselage of the aircraft around its center of mass doesn't depend on the placement of the engine (is opposite to the engine torque)?
I tried a derivation using a force couple:
F0 = -F1
T = r0 x F0 + r1 x F1
Tcom = (r + r0) x F0 + (r + r1) x F1 = r0 x F0 + r1 x F1 + r x (F0 + F1) = T
Fcom = F0 + F1 = 0
Right?
log0 said:
F0 = -F1
Fcom = F0 + F1 = 0
(try using the X2 tag just above the Reply box :wink:)
Yes, that's right …
when you change the "centre" by a displacement r, you add r x Fnet to the moment, and Fnet is zero for a couple (a pure moment). :smile:
OK, Thanks tiny-tim. :smile:
  • · Replies 49 ·
