What is the rate of heat loss through an insulated wall with glass wool?
The rate of heat loss through an insulated wall using glass wool with a thermal conductivity of K = 0.046 W/m°C can be calculated using the formula Q = (K * A * ΔT) / L. For a wall area of 1.0 m by 1.5 m, insulated with a 20 cm thick layer of glass wool and a temperature difference of 20.0°C, the correct calculation yields a heat loss of 4.6 W. The initial error in calculation was due to incorrect area input, which was clarified during the discussion.
  • Understanding of thermal conductivity and its units
  • Familiarity with the formula for heat transfer through materials
  • Basic algebra skills for manipulating equations
  • Knowledge of unit conversions, particularly between meters and centimeters
  • Study the principles of heat transfer, focusing on conduction
  • Learn about different insulation materials and their thermal properties
  • Explore advanced heat transfer calculations involving multiple layers of insulation
  • Investigate the impact of temperature gradients on heat loss in building materials
Students in physics or engineering courses, construction professionals, and anyone involved in building insulation and energy efficiency assessments.
kboykb
A wall is insulated with glass wool of thermal conductivity K = 0.046 W/m oC. What is the rate of heat loss (in W) through an area 1.0 m wide by 1.5 m high, insulated with a layer of glass wool 20 cm (.2 m) thick, if the temperature difference across the layer is 20.0 oC?
I think I'm just doing something wrong algebraically. I'm using Q/deltaT = KA * delta T/L
Finding the area first (l*w?) = 1.0 m * .2m = .2m
Then
(0.046 * .2) * (20/.2) = .92 degrees
Do your units match up?
I got it right :-) Sorry, I'm a noob. I was plugging in the wrong Area, and it was causing my number to come out wrong.
Thanks!
15K
