What properties of a material make it a good insulator and opaque?
  • Thread starter Thread starter chmmr
    Insulation
This discussion focuses on the properties that make materials good insulators and opaque. It establishes that a material's transparency often indicates a large band gap, preventing electron movement and thus making it a good insulator. However, materials like NaCl can be transparent yet poor insulators due to ionic conduction. Opaque insulators, such as ceramics and colored plastics, may absorb light at high frequencies, while the discussion also highlights the misconception regarding optical fibers, which can be opaque yet function effectively in infrared applications.
  • Understanding of band gap theory in materials science
  • Knowledge of ionic vs. electronic conduction mechanisms
  • Familiarity with the electromagnetic spectrum, particularly visible and infrared light
  • Basic principles of semiconductor physics, including transparent conductors
  • Research the properties of materials with large band gaps and their applications
  • Explore the mechanisms of ionic conduction in materials like NaCl
  • Investigate the characteristics of opaque ceramics and colored plastics as insulators
  • Learn about transparent conductive oxides such as Indium Tin Oxide (ITO) and their uses in technology
Materials scientists, electrical engineers, and students studying semiconductor physics will benefit from this discussion, particularly those interested in the relationship between material properties and their applications in technology.
chmmr
This is a multi-part problem.
Visible light spans a range of wavelength between 0.4-0.7 nm, corresponding to a photon energy between about 1.8 and 3.1 eV.
(a) An old practical test says that if you can see through a piece of material, it is almost certainly a good insulator. Why?
(b) Why the modifier "almost"? How can a transparent material fail to be a good insulator? Hint: You can see through NaCl if you squint, but it is not a very good insulator.
(c) On the other hand, there are many good insulators that you cannot see through, including both opaque ceramics and brightly colored plastics. Describe at least one possible microstructure that creates an opaque insulator.
(d) Alvin, a random undergraduate of great academic promise, got a summer job with a technology company. He was assigned to the mail room. While inspecting incoming materials, he came across a box labeled optical fibers, which were metallic gray in color and totally opaque. He sent them back as rejects. His boss fired him, saying, "The fibers you returned were super-high-tech fibers for use with our hot new semiconductor lasers, and were desperately needed. They are exceptionally clear and transparent." What was Alvin's mistake?
None.
I read this https://www.physicsforums.com/showpost.php?p=899393&postcount=4 but I don't think it's the model my teacher uses.
(a) Since emitted light is caused by electrons moving from high energy states to low energy states across a band gap, if it is transparent it means the band gap is larger than 3.1 eV. Since the band gap is so large electrons cannot cross from the valence band to the conduction band.
What I want to know is, what happens when the energy gap is less than 1.8 eV? I know if there is no band gap, the material is a conductor and the appearance is metallic. But shouldn't it be transparent as well?
I suspect it has something to do with the post I linked at the top, but I don't know how.
(b) Because NaCl is an ionic conductor, it does not conduct by electrons, but whole ions, which are unrelated to opacity.
(c) This question is the one I'm having the most trouble with. The only thing I can think of is that the plastic absorbs light at a high frequency (above visible) and emits light at a lower, visible frequency.
(d) The "hot new semiconductor laser" emits light that is in the infrared, so the fibers do not need to respond to visible light.
If you can see though it then it's probably an insulator because electromagnetic waves can only penetrate a short distance into a conductor. The better the conductor, the shallower the penetration.
Exception: semiconductors like ITO and Tin Oxide. These are transparent conductors.
  • · Replies 0 ·
  • · Replies 22 ·
