Thread Closed
Eigenvalues and eigenvectors of a 3x3 matrix (principal stresses)[programming]
Share Thread Thread Tools
Apr15-10, 02:08 PM   #1
I need to compute the 3 eigenvalues and 3 eigenvectors of a symmetric 3x3 matrix, namely a stress tensor, computationaly (in C++). More specific details here. Basically 2 questions:
1. I am running into trouble in finding the 3 real roots. Here we have the general formula for the roots. According to Wikipedia, again, "The characteristic equation has three real roots λ, i.e. not imaginary due to the symmetry of the stress tensor.", then I'm sure these huge formulas can be simplified, and it is indeed a hard work to try simplifying it. Have you ever seen a simplified formula for cubic equations where the discriminant is always greater than zero (then, three real roots).
2. After finding the eigenvalues how to find the eigenvectors? I read about general purpose methods like the Power Method but these are for nxn matrices. For a 3x3 matrix there must be a much simpler technique.
Thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Apr15-10, 02:52 PM   #2
Recognitions:
Homework Helper Homework Help
You can find the eigenvector belonging to eigenvalue [itex]\lambda[/itex] by solving the system of equations [itex]Tv=\lambda v[/itex]. You will get three equations which you can solve for v_1,v_2 and v_3.
Apr15-10, 03:13 PM   #3
Quote by Cyosis View Post
I know how to do this with pencil and paper, or in my mind perhaps ^^. But how to do it in programming? I don't know methods to compute a solution space (not only a single solution as most usual methods do like Gauss Seidel, Conugate Gradients, etc)..
Apr15-10, 08:07 PM   #4
Mathematica would just give you the answer, Eigenvalues[matrix], done. To calculate yourself, sure get your cubic polynomial and figure out a way to solve it, numerically perhaps???
Apr15-10, 08:36 PM   #5
There's probably an even easier way for 3x3 matrices, but Jacobi (Givens) rotation is fairly easy to code and should be quick. See http://scholar.lib.vt.edu/theses/ava.../chapter5a.PDF and http://en.wikipedia.org/wiki/Jacobi_...alue_algorithm.
edit: Actually this page is more describing than the other Wikipedia link imho: http://en.wikipedia.org/wiki/Jacobi_rotation
Apr15-10, 09:10 PM   #6
Quote by jrosen13 View Post
Actually, I have to implement it myself in C++ code. Since there's a formula for the exact solution of a cubic equation I think its better to use it then. Numerical methods have problems finding all roots, don't they?
Quote by Lord Crc View Post
Uh I think using these methods is a waste for 3x3 matrices. After looking more thoroughly into this problem I got a few conclusions which Im still unsure about. The eigen space of λ (vector space generated by all eigenvectors of λ) is the null space of the matrix (A-λI), or equivalently the solution space of the system (A-λI)x=0. We know that the row space of a matrix is orthogonal to its null space, then we can compute the eigenvector(s) of an eigenvalue by verifying the linear independence of the rows of (A-λI). I could compute the cross product of two pairs of row vectors, like r0Xr1 and r1Xr2 , then
-if these two cross products are zero, the rows of (A-λI) are linearly dependent, then the eigenspace is a plane orthogonal to any of the rows of (A-λI)
-if one of the cross products is different zero, then the cross product is the eigenvector itself
-it should not be possible for both to be different zero because then the eigenspace would be zero dimensional
What you think eh???
Thanks
Apr15-10, 09:18 PM   #7
Quote by xiss burg View Post
Perhaps. All I know is that it would get you the eigenvalues and the eigenvectors in one go, and the code I got is shorter than the stable cubic equation solver I use (formatted C).
Apr26-10, 12:51 PM   #8
Now I see that its better to use a numerical method, specially because I don't need a very accurate approximation for my specific application. Then I will give a try to that Jacobi method. Do you guys think this is one of the best choices for symmetrical 3x3 matrices?
Thanks.
Apr26-10, 01:05 PM   #9
That was my feeling before, that numerically you can solve a cubic polynomial to whatever accuracy you desire, up to some fundamental limit of time cost perhaps, but that you should be able to get really close without too much trouble. However, it is possible to analytically solve it!!! e.g. http://en.wikipedia.org/wiki/Cubic_function
That should be really fast! And exact too!
Thread Closed
Thread Tools
Similar Threads for: Eigenvalues and eigenvectors of a 3x3 matrix (principal stresses)[programming]
Thread Forum Replies
Eigenvalues and eigenvectors of symmetric 2x2 matrix? Linear & Abstract Algebra 5
The Eigenvalues and eigenvectors of a 2x2 matrix Calculus & Beyond Homework 1
Eigenvalues and eigenvectors of this matrix Linear & Abstract Algebra 1
eigenvalues & eigenvectors of N x N matrix? Linear & Abstract Algebra 8
