People ever add d3x/dt3 to Newton's second law?
The discussion revolves around the consideration of higher-order derivatives, specifically the third derivative of position with respect to time (d3x/dt3), in the context of Newton's second law and its applications in physics and engineering. Participants explore the relevance and necessity of these derivatives in various scenarios, including engineering design and theoretical physics.
  • Experimental/applied
  • Some participants question the necessity of adding d3x/dt3 to Newton's second law, noting that it is not defined within that framework.
  • Others argue that while the third derivative has useful meanings, it is not commonly found in fundamental principles due to the nature of forces and their measurements.
  • One participant highlights the importance of higher-order derivatives, particularly in engineering contexts like roller coaster design, where terms like 'jerk' (d3x/dt3) and 'jounce' (d4x/dt4) are used.
  • Another participant mentions that the Beam equation is a third-order equation, while others clarify that it is often a fourth-order equation in elasticity.
  • There is a discussion about the naming conventions for higher-order derivatives, with some participants noting the rarity of these terms beyond 'jerk' and 'snap'.
  • A participant introduces the Lorentz-Dirac equation as a well-known third-order equation, discussing its problematic solutions related to acceleration.
  • Fluid mechanics is mentioned as a field where fourth-order differential equations may be used, particularly in the context of the vorticity equation.
  • Some participants express uncertainty about the application of higher-order derivatives and their relevance in describing physical phenomena.
  • There is a challenge to the integration methods discussed, with one participant asserting that assumptions about constant velocity lead to oversimplifications.
Participants express a range of views on the relevance and application of higher-order derivatives, with no clear consensus on their necessity in the context of Newton's second law or their broader implications in physics and engineering.
Some discussions highlight limitations in assumptions about constant velocity and the integration process, indicating that the treatment of these derivatives may depend on specific contexts and definitions.
Gonzolo
The differential equations that are mostly used in physics are second order, so I am wondering about the third order (or more)? It is clear that in real life, like when driving a car, acceleration changes many times and continuously, but do people ever add d3x/dt3 to Newton's second law? Is it ever necessary?
Science news on Phys.org
Well you don't see it added to Newton's second law because Newton's second law isn't defined with it.
The third derivative certainly has useful meaning, but you really don't see it in fundamental principles because fundamental forces aren't known to change in a measurable way without some other variable changing.
For instance, if you changed the voltage on an anode the position of the electrons moving to it would not be your usual square graph of distance over time. However, that doesen't mean there is a d3x/dt3 in the electromagnetic equations; maxwell's equations didn't change, just the situation.
It's important in some areas of engineering especially rollercosater design (I saw program on the telly about this) and it's usually called 'jerk' (though it is also called 'jolt' and 'surge'). In fact sometimes even higher order derivatives of postion and time are useful and are also known by names (such as jounce for the the fourth derivative).
edited to add: you may suprised to learn on a rollercoaster in general even the jounce is not constant.
It's not necessary to consider higher order derivatives.
Galileo (not me) and Newton ofcourse knew that position is relative furthermore
they have shown experimentally that velocity is also relative. You wouldn't
know if you were moving if you are in a train (or in Galileo's case a ship) if
you didn;t look outside. All physical measurements give the same results.
Contrast the case when accelerations are present.
Acceleration is NOT relative, so that should be your object of study.
In engineering I believe that the Beam equation is 3rd order.
Edit:
Humm... a quick web search shows a 4th order equation.. no time for further research at this time.
Yes, integral, the beam equation and, more generally, equations in elasticity are 4th order.
As far as the names of those derivatives go, for kinematic quantities, as far as I know it goes:
velocity, acceleration, jerk, snap, crackle, pop, (never heard of a term for anything higher)
I've heard of jolt and jounce (I believe as UK alternatives for jerk and snap). And I guess it's so rare in practice to see those derivatives that the names aren't official (at least beyond jerk and definitely beyond snap). Anyway, when I saw the thread I though I'd just point that out as a point of interest.
Just in case fourth order derivatives are too boring, You can always try your hand at finite element analysis with the Gear algorithm, which uses fifth order derivatives. Personally, it only takes third order derivatives to put me into a coma.
A well known third order equation is the Lorentz-Dirac equation; it describes the motion of a classical relativistic point charge interacting with its own fields. Its solutions show problematic results: either runaway acceleration (ie the particle spontaneously accelerates to arbitrary speeds), or non-causal acceleration (the particle accelerates before an external force is turned on). The latter occurs for an interval of time roughly equal to the time light takes to travel the 'classical radius' of the object.
Wow! Thanks! I'm all primed up to learn how to solve them now!
In fluid mechanics, it is occasionally convenient to work with the vorticity equation expressed in terms of the stream function; this is a 4th order differential equation.
Actually, I'm not sure I'll go there anytime soon. But it's nice to know they are not forgotten and actually useful.
I tried to forget it right after my exams..:biggrin:
I think that a phenomenon in physics cannot be described with differential equation.
If you have dx=Vdt then you have actually differentiated x=Vt assuming V=const.
I just don't know any other way to come up with dx=Vdt except by derivating x=Vt assuming V=const.
This means that your describtion of the phenomenon represents special case.
If you have complete differential equation (dx=Vdt+tdV) then you actually have nondifferential one (x=Vt).
You are integrating incorrectly. Firstly, you aren't including the limits of integration, such as they might be. Secondly, you are assuming in your integration that V is a constant, and then acting suprised when it turns out that way.
  • · Replies 16 ·
  • · Replies 27 ·
  • · Replies 117 ·
10K
  • · Replies 240 ·
23K
