Simulating System of Masses Connected by Springs
  • Thread starter Thread starter 200917717
    Springs System
The discussion revolves around simulating a system of masses connected by springs, focusing on the parameters of the masses and springs, the equations governing their motion, and the implementation of a code to visualize the simulation over a specified time frame. Participants are addressing issues related to code compilation, error messages, and the accuracy of the resulting plots.
  • Homework-related
  • One participant presents a detailed setup for a simulation involving masses and springs, including their properties and the equations to be used.
  • Another participant questions whether the provided code compiles and runs successfully, seeking clarification on the results obtained.
  • Several participants report issues with code compilation, specifically citing error messages related to missing variables or functions.
  • There is a discussion about a specific line of code that is causing compilation issues, with suggestions to correct the syntax by using proper commenting methods.
  • One participant mentions that their modified code compiles but does not produce an accurate plot, indicating potential issues with the simulation logic or parameters.
  • There are multiple references to the need for clarity in the code to facilitate troubleshooting and understanding among participants.
Participants do not reach a consensus on the correctness of the code or the accuracy of the simulation results. Multiple competing views and unresolved issues regarding code errors and plotting accuracy remain evident.
Participants express uncertainty regarding specific lines of code and the implications of certain calculations. There are unresolved questions about the accuracy of the simulation results and the effects of various parameters on the output.
This discussion may be useful for students or individuals interested in computational physics, simulation of mechanical systems, or those seeking assistance with coding in a physics context.
200917717
https://www.physicsforums.com/attachments/251691. Homework Statement
assigned system of masses connected by springs with the parameters specified
Mass M0 details:
Stationary mass, does not move
Starting Positions in meters:
X: 5.8
Y: 4.2
Mass M1 details:
Mass 14 kg
X: 5.8
Y: 3
Mass M2 details:
Mass 16 kg
X: 5.4
Y: 5.6
Mass M3 details:
Mass 14 kg
X: 4.2
Y: 4.8
Spring S0 details:
K: 0.78
Equilibrium Distance (meters):
Eq: 0.9
Spring S1 details:
K: 0.7
Eq: 1.6
Spring S2 details:
K: 1.02
Eq: 1.3
Spring S3 details:
K: 0.78
Eq: 1
Spring S4 details:
K: 0.66
Eq: 0.8
Using model it must simulate the movement of all the masses from 0 to 100 seconds (including 100) with a time step of 0.1 seconds. Record the position of each mass (X and Y position) at every time step in an array. You will then plot the path of each mass in a different colour on a single plot with the X Axis to run from 0 to 10 meters and the Y axis from 0 to 7.5 meters.No friction or gravity
F=-kx where k is the spring constant and x is the displacement from the springs equilibrium point.
Fx=Fcos(θ) where Theta is the angle at which the spring is pulling.
Fy=Fsin(θ)
You add up all the X component forces and Y component forces for a specific mass to find the result X and Y component force acting on that mass. Once you have the resultant force acting on a specific mass you can find its Acceleration from the following:
Fres = ma thus a = m/Fres
a=∆v/∆t thus ∆V=a∆t
∆V= ∆s/∆t thus ∆s= ∆v∆t
code for start
clear all;
close all;
clc;
%position of peg
pegX = 5.8;
pegY = 4,2;
%position of mass
xPos1 = 5.8;
yPos1 = 3;
xPos2 = 5.4;
yPos2 = 5.6;
xPos3 =4.2 ;
yPos3 = 4.8;
%velocity of mass
xVel1 = 0;
yVel1 = 2;
xVel2 = 1.67;
yVel2 = 2.79;
xVel3 = -0.64;
yVel3 = -3.19;
xVel4 = -6;
yVel4 = 5;
%mass of mass
m1 = 14;
m2 = 16;
m3 = 14;
%constant of spring
kpeg = 0.78;
k1 = 0.7;
k2 = 1.02;
k3 = 0.78;
%equilibrium distance of spring
egpeg = 0.9;
eq1 = 1.6;
eq2 = 1.3
eq3 = 1;
%constant of gravity
g = 0.5;
%define time domain
dt = 0.1;
t = 0:dt:100;
%record all previos positions for plot
positions = zeros(4,length(t));
for i = 1:length(t)
%find angle between peg and mass
theta1 = direction(xPos1,yPos1,pegX,pegY);
theta2 = direction(xPos3,yPos3,xPos1,yPos1);
theta3 = direction(xPos2,yPos2,xPos3,yPos3);
theta4 = direction(xPos1,yPos1,xPos2,yPos2);
theta5 = direction(pegX,pegY,xPos2,yPos2);
%calc X resultant force
FresX1 = -1*(eq1-dist(xPos1,yPos1,pegX,pegY))*k1*cos(theta1);
FresX2 = -1*(eq2-dist(xPos2,yPos2,xPos1,yPos1))*k2*cos(theta2);
FresX3 = -1*(eq3-dist(xPos3,yPos3,xPos2,yPos2))*k2*cos(theta3);
%calc Y resultant force
FresY1 = -1*(eq1-dist(xPos1,yPos1,pegX,pegY))*k1*sin(theta1) - m1*g;`clear all;
FresY3 = -1*(eq3-dist(xPos3,yPos3,xPos1,yPos1))*k3*sin(theta2) - m3*g;`clear all;
FresY2 = -1*(eq2-dist(xPos2,yPos,xPos3,yPos3))*k2*sin(theta3) - m2*g;`clear all;
FresY4 = -1*(eq1-dist(xPos1,yPos1,xPos2,yPos2))*k1*sin(theta4) - m1*g;`clear all;
FresY5 = -1*(eqpeg-dist(xPospegx,yPospegy,xPos2,yPos2))*kpeg*sin(theta5) - mpeg*g;`clear all;
%calculate acceleration due to force
aX1 = FresX1/m1;
aY1 = FresY1/m1;
aX2 = FresX2/m2;
aY2 = FresY2/m2;
aX3 = FresX3/m3;
aY3 = FresY3/m2;
%change velocity based on acceleration
xVel1 = xVel1 + aX1*dt;
yVel1 = yVel1 + aY1*dt;
xVel2 = xVel2 + aX2*dt;
yVel2 = yVel2 + aY2*dt;
xVel3 = xVel3 + aX3*dt;
yVel3 = yVel3 + aY3*dt
%change position based on velocity
xPos1 = xPos1 + xVel1*dt;
yPos1 = yPos1 + yVel1*dt;
xPos2 = xPos2 + xVel2*dt;
yPos2 = yPos2 + yVel2*dt;
xPos3 = xPos3 + xVel3*dt;
yPos2 = yPos3 + yVel3*dt;
%record position for plot
positions(1,i) = xPos1;
positions(2,i) = yPos1;
positions(3,i) = xPos2;
positions(4,i) = yPos2;
positions(5,i) = xPos3;
positions(6,i) = yPos3;
end
%plot position
p1 = plot(positions(1,:),positions(2,:),'r');
p2 = plot(positions(3,:),positions(4,:),'b');
p2 = plot(positions(5,:),positions(6,:),'g');
grid on;
Code for direction:
function [ a ] = direction(x1,y1,x2,y2 )
%DIRECTION find direction of line between the 2 points
a = atan2(y2-y1,x2-x1);
end
code for distance:
function [ d] = dist( x1,y1,x2,y2)
%DIST calculate euclidian distance between 2 points
d = sqrt((x1-x2)^2+(y1-y2)^2);
end
Does your code compile and run? What results did you get?
the code for start could not be compiled
Did you get any error messages? Help us out here. Don't make us pick through 50 or so lines of code to see what the problem might be.
yes,These was the first errow"? Error: File: E:\prac.m Line: 61 Column: 73
Missing variable or function."I don't know if there are more
Count down to line 61. What is the code in that line?
That's not all that's on that line.
FresY1 = -1*(eq1-dist(xPos1,yPos1,pegX,pegY))*k1*sin(theta1) - m1*g; `clear all;[/color]
I believe that part in red is causing your problem. Use % for comments. There's another form of comment that uses ' followed by an ellipsis (...), but you don't have the three dots.
I tried the following code,it compiled but does not display the accurate plot:
clear all;
close all;
clc;
%position of peg
pegX = 5.8;
pegY = 4,2;
%position of mass
xPos1 = 5.8;
yPos1 = 3;
xPos2 = 5.4;
yPos2 = 5.6;
xPos3 =4.2 ;
yPos3 = 4.8;
%velocity of mass
xVel1 = 0;
yVel1 = 2;
xVel2 = 1.67;
yVel2 = 2.79;
xVel3 = -0.64;
yVel3 = -3.19;
xVel4 = -6;
yVel4 = 5;
%mass of mass
m1 = 14;
m2 = 16;
m3 = 14;
%constant of spring
kpeg = 0.78;
k1 = 0.7;
k2 = 1.02;
k3 = 0.78;
egpeg = 0.9;
eq1 = 1.6;
eq2 = 1.3
eq3 = 1;
%define time domain
dt = 0.1;
t = 0:dt:100;
for i = 1:length(t)
theta1 = direction(xPos1,yPos1,pegX,pegY)+direction(xPos1,yPos1,peg3,peg3)+direction(xPos1,yPos1,peg2,peg2);
theta2 = direction(xPos3,yPos3,xPos1,yPos1)+direction(xPos3,yPos3,xPos2,yPos2);
theta3 = direction(xPos2,yPos2,xPos3,yPos3)+ direction(xPos2,yPos2,xPos1,yPos1)+direction(xPos2,yPos2,pegX,pegy);
FresY1 = -1*(eq1-dist(xPos1,yPos1,pegX,pegY))*k1*sin(theta1);
FresY3 = -1*(eq3-dist(xPos3,yPos3,xPos1,yPos1))*k3*sin(theta2);
FresY2 = -1*(eq2-dist(xPos2,yPos2,xPos3,yPos3))*k2*sin(theta3);
FresY4 = -1*(eq1-dist(xPos1,yPos1,xPos2,yPos2))*k1*sin(theta3);
aX1 = FresX1/m1;
aY1 = FresY1/m1;
aX2 = FresX2/m2;
aY2 = FresY2/m2;
aX3 = FresX3/m3;
aY3 = FresY3/m3;
yPos3 = yPos3 + yVel3*dt;
end
%plot position
p2 = plot(positions(3,:),positions(4,:),'g');
p3 = plot(positions(5,:),positions(6,:),'r');
grid on
So at least now your code compiles. Can you be more specific about what you mean when you say it doesn't display the accurate plot? You're calling the plot function three times. Are all three not displaying correctly? What does each one display?
programme does not plot the paths of each mass on a single plot in different colour,it just plot a sigle line for the last plot 3 only.
Can you please check for me; whether my velocities of masses are correct .There is a sketch in the attatchement for reference
As far as I'm concerned, that's really up to you. I'm just helping to get your code running.
I tried the these code,but it plots for mass3 only
function [c]=tall
clear all;
close all;
clc;
%position of peg
pegX = 5.8;
pegY = 4.2;
%position of mass
xPosm1 = 5.8;
yPosm1 = 3;
xPosm2 = 5.4;
yPosm2 = 5.6;
xPosm3 =4.2 ;
yPosm3 = 4.8;
%velocity of mass
xVelm1 = 0;
yVelm1 = 0;
xVelm2 = 0;
yVelm2 = 0;
xVelm3 = 0;
yVelm3 = 0;
%mass of mass
m1 = 14;
m2 = 16;
m3 = 14;
%constant of spring
kpeg = 0.78;
k1 = 0.7;
k2 = 1.02;
k3 = 0.78;
k4 = 0.66;
eqpeg = 0.9;
eq1 = 1.6;
eq2 = 1.3;
eq3 = 1;
eq4 = 0.8;
%define time domain
dt = 0.1;
t = 0:dt:100;
positionsm1= zeros(2,length(t));
positionsm2= zeros(2,length(t));
positionsm3= zeros(2,length(t));
for i = 1:length(t)
%find angle between peg, mass1, mass2 and mass3
thetam1peg = direction(xPosm1,yPosm1,pegX,pegY);
thetam13 = direction(xPosm1,yPosm1,xPosm3,yPosm3);
thetam12 = direction(xPosm1,yPosm1,xPosm2,yPosm2);
%find angle between peg, mas1, mass2 and mass3
thetam2peg = direction(xPosm2,yPosm2,pegX,pegY);
thetam21 =direction(xPosm2,yPosm2,xPosm1,yPosm1);
thetam23 = direction(xPosm2,yPosm2,xPosm3,yPosm3);
%find angle between mas1,mass2 and mass3
thetam31 = direction(xPosm3,yPosm2,xPosm1,yPosm1);
thetam32 =direction(xPosm3,yPosm2,xPosm2,yPosm2);
%calc X resultant force of m1
FresXm1 = -1*(eqpeg-dist(xPosm1,yPosm1,pegX,pegY)*kpeg*cos(thetam1peg))-1*(eq4-dist(xPosm1,yPosm1,xPosm3,yPosm3)*k4*cos(thetam13)) -1*(eq2-dist(xPosm1,yPosm1,xPosm2,yPosm2)*k2*cos(thetam12));
%calc X resultant force of m2
FresXm2 = -1*(eq1-dist(xPosm2,yPosm2,pegX,pegY)*k1*cos(thetam2peg))-1*(eq2-dist(xPosm2,yPosm2,xPosm1,yPosm1)*k2*cos(thetam21)) -1*(eq3-dist(xPosm2,yPosm2,xPosm3,yPosm3)*k3*cos(thetam23));
%calc X resultant force of m3
FresXm3 = -1*(eq4-dist(xPosm3,yPosm3,xPosm1,yPosm1)*k4*cos(thetam31))-1*(eq3-dist(xPosm3,yPosm3,xPosm2,yPosm2)*k3*cos(thetam32));
%calc Y resultant force of m1
FresYm1 = -1*(eqpeg-dist(xPosm1,yPosm1,pegX,pegY)*kpeg*sin(thetam1peg))-1*(eq2-dist(xPosm1,yPosm1,xPosm2,yPosm2)*k2*sin(thetam12)) -1*(eq4-dist(xPosm1,yPosm1,xPosm3,yPosm3)*k4*sin(thetam13));
%calc Y resultant force of m2
FresYm2 = -1*(eq1-dist(xPosm2,yPosm2,pegX,pegY)*k1*sin(thetam2peg))-1*(eq2-dist(xPosm2,yPosm2,xPosm1,yPosm1)*k2*sin(thetam21)) -1*(eq3-dist(xPosm2,yPosm2,xPosm3,yPosm3)*k3*sin(thetam23));
%calc Y component force of m3
FresYm3 = -1*(eq4-dist(xPosm3,yPosm3,xPosm1,yPosm1)*k4*sin(thetam31))-1*(eq3-dist(xPosm3,yPosm3,xPosm2,yPosm2)*k3*sin(thetam32));
aXm1 = FresXm1/m1;
aYm1 = FresYm1/m1;
aXm2 = FresXm2/m2;
aYm2 = FresYm2/m2;
aXm3 = FresXm3/m3;
aYm3 = FresYm3/m3;
xVelm1 = xVelm1 + aXm1*dt;
yVelm1 = yVelm1 + aYm1*dt;
xVelm2 = xVelm2 + aXm2*dt;
yVelm2 = yVelm2 + aYm2*dt;
xVelm3 = xVelm3 + aXm3*dt;
yVelm3 = yVelm3 + aYm3*dt
xPosm1 = xPosm1 + xVelm1*dt;
yPosm1 = yPosm1 + yVelm1*dt;
xPosm2 = xPosm2 + xVelm2*dt;
yPosm2 = yPosm2 + yVelm2*dt;
xPosm3 = xPosm3 + xVelm3*dt;
yPosm3 = yPosm3 + yVelm3*dt;
positionsm1(1,i) = xPosm1;
positionsm1(2,i) = yPosm1;
positionsm2(3,i) = xPosm2;
positionsm2(4,i) = yPosm2;
positionsm3(5,i) = xPosm3;
positionsm3(6,i) = yPosm3;
end
%plot position
p1 = plot(positionsm1(1,:),positionsm1(2,:),'r');
hold all
p2 = plot(positionsm2(3,:),positionsm2(4,:),'g');
hold all
p3 = plot(positionsm3(5,:),positionsm3(6,:),'b');
grid on
