Thermodynamics: Calculating Outside Temperature of a Greenhouse with Heat Loss
  • Thread starter Thread starter pinnacleprouk
    Thermodynamics
The discussion focuses on calculating the outside temperature of a greenhouse given a heat loss rate of 120 kW through a 10mm-thick glass roof. The dimensions of the roof are 20m by 2m, and the internal temperature is set at 25 degrees Celsius. The thermal conductivity of the glass is specified as 1.0 W/m/°C. Participants emphasize the importance of using the heat conduction equation, which relates heat transfer to temperature differences and thermal conductivity, to solve the problem effectively.
  • Understanding of heat transfer principles, specifically conduction.
  • Familiarity with the heat conduction equation: Q = k * A * (T1 - T2) / d.
  • Basic knowledge of thermal conductivity and its units.
  • Ability to manipulate equations to isolate variables.
  • Review the heat conduction equation in your textbook or lecture notes.
  • Learn how to calculate temperature differences using thermal conductivity.
  • Explore practical applications of thermal conductivity in building materials.
  • Investigate methods to minimize heat loss in greenhouse design.
Students studying thermodynamics, engineers involved in building design, and anyone interested in optimizing greenhouse environments for better temperature control.
pinnacleprouk
The rate of heat loss to the outside through a 10mm-thick glass roof of a green house is 120kW. The length and breadth of the glass material of the roof are 20m and 2m, respectively. Calculate the temperature of the outside if the temperature inside the green-house is 25 degrees C.
Assume thermal conductivity of the glass material is 1.0W/m/degrees C.
Please help as I don't know where to start.
I'm not sure where to start unfortuanatly.
Thanks in advance!
There is an equation that relates heat conducted and temperature. It involves the thermal conductivity too.
The fact that you have been assigned this problem means that this equation is somewhere in your textbook, lecture notes, or class handouts. Find this equation in your textbook, lecture notes, or class handouts -- that is where to start.
  • · Replies 33 ·
  • · Replies 16 ·
