Calculate Parameters of Shifted Exponential Density from Measurements
This discussion focuses on estimating the parameters of a shifted exponential density function, specifically the parameters L and t0, from a vector of sample times X. The density function is defined as f(t) = L * e^(-L(t-t0)) * u(t-t0), where u(t) is the unit step function. The posterior probability density function f(L, t0 | X) can be calculated using Bayes' theorem, leading to the expectations of L and t0 being computed through numerical integration methods. The normalization constant K is derived from the integral of f(X | L, t0) over the specified ranges.
  • Understanding of Bayes' theorem and its application in probability density functions.
  • Familiarity with exponential functions and unit step functions in mathematical modeling.
  • Knowledge of numerical integration techniques for solving complex integrals.
  • Experience with vector and matrix operations in statistical analysis.
  • Learn about numerical integration methods such as Monte Carlo integration for estimating parameters.
  • Study the application of Bayesian statistics in parameter estimation for probabilistic models.
  • Explore the use of Python libraries like SciPy for implementing numerical solutions to integrals.
  • Investigate the properties of shifted exponential distributions and their applications in real-world scenarios.
Statisticians, data scientists, and researchers involved in probabilistic modeling and parameter estimation, particularly those working with Bayesian methods and exponential distributions.
hkBattousai
I have a density function:
f(t) = L * e-L(t-t0) * u(t-t0)
And I have a column vector X, which is randomly chosen samples from f(t):
X = [x1 x2 ... xn]T
How can I estimate the unknown values t0 and L from this X vector?
You can use Bayes' theorem to calculate a (posterior) probability density function f(L, t0 | X) for the parameters L and t0 given the vector of sample times X:
If we call
f(t | L, t0) = L * e-L(t-t0) * u(t-t0)
and
f(X | L, t0) = f(x1 | L, t0)*f(x2 | L, t0)*...*f(xn | L, t0)
We can calculate the posterior PDF
f(L, t0 | X) = f(X | L, t0) / K
where K is a nornlization constant
[tex]K = \int_{L=0}^{\infty} \int_{t_0=0}^{\infty} f(X | L, t0) dt_0 dL[/tex]
(above I have assumed a homogeneous prior distributions for L and t0)
You can then e..g. calculate expectations of L and t0 from f(L, t0 | X)
[tex]\hat{L} = \int_{L=0}^{\infty} \int_{t_0=0}^{\infty} L* f(L, t0 | X) dt_0 dL[/tex]
[tex]\hat{t_0} = \int_{L=0}^{\infty} \int_{t_0=0}^{\infty} t_0* f(L, t0 | X) dt_0 dL[/tex]
The integrals are probably difficult to solve analytically, but you can solve them numarically given your X-vector.
