How to Find the Ka of an Acid from pH and Titration Data?
The discussion focuses on calculating the acid dissociation constant (Ka) of a solid acid using pH and titration data. The procedure involves titrating 40.0 mL of the acid solution with NaOH to a phenolphthalein endpoint and subsequently mixing the neutralized solution with the remaining acid solution, resulting in a pH of 3.35. The relationship between the concentrations of the acid (HA), its conjugate base (A-), and the hydrogen ion concentration ([H+]) is crucial for determining Ka using the formula: (concentration of HA)/(concentration of A-) = (volume of acid)/(volume of base) = (concentration of H+)/(Ka).
  • Understanding of acid-base titration techniques
  • Knowledge of pH calculations and their implications
  • Familiarity with the concept of conjugate acids and bases
  • Proficiency in using the formula for Ka calculations
  • Study the principles of acid-base titration and endpoint determination
  • Learn how to calculate pH from hydrogen ion concentration
  • Explore the relationship between pH, pKa, and Ka
  • Investigate the use of phenolphthalein as an indicator in titrations
Chemistry students, laboratory technicians, and educators involved in acid-base chemistry and titration methodologies.
Jade_punk181
A solid acid is dissolved in enough water to make 200 mL of a solution. 40.0 mL of the solution is titrated to a phenolphtalein end point with an NaOH solution. The neutralized solution and the remainder of the acid solution are then mixed and the pH of the resulting solution is found to be 3.35. Find the Ka of the acid.by trying to figure out this problem, I assumed that the following formula would come in useful:
((concentration of HA)/(concentration of A-))=volume of acid/volume of base=((concentration of H+)/(Ka))I have attempted this problem, but the equations I had weren't fit for this problem.
After mixing you have a solution containing acid and its conjugate base in known proportions.
