Perturbation Theory/Harmonic Oscillator
by Void123
Tags: oscillator, perturbation, theory or harmonic
Void123
Void123 is offline
#1
Apr20-10, 10:46 PM
P: 139
I am given the hamiltonian, where [tex]H^{^}_{0}[/tex] is that of the harmonic oscillator and the perturbation is (lambda)*(h-bar)*(omega)*[(lowering operator)^2 + (raising operator)^2]. I am asked to find the ground state, second-order approx. energy value.
2. Relevant equations
Second order eigenenergy equation.
3. The attempt at a solution
I have written out the whole hamiltonian. Do I need to expand the lowering-raising operators in terms of n? I am a bit lost on what to plug in to the second order equation for the two wave functions m and n (which sandwich the Hamiltonian operator).
Phys.Org News Partner Science news on Phys.org
Cougars' diverse diet helped them survive the Pleistocene mass extinction
Cyber risks can cause disruption on scale of 2008 crisis, study says
Mantis shrimp stronger than airplanes
kuruman
kuruman is offline
#2
Apr21-10, 12:10 PM
HW Helper
PF Gold
kuruman's Avatar
P: 3,444
You know that the "meat" of the sandwich is the perturbing Hamiltonian,
[tex]H'=\hbar\omega(a_+^2+a_-^2)[/tex]
Since you are looking for the second order correction to the ground state, one of the "breads", say the bra, should be <0|. Suppose you were to write the other "bread" (the ket) as |n>. What do you get when you operate on that with a+2 and a-2? What does the resulting ket need to be in order not to have a zero matrix element?
Void123
Void123 is offline
#3
Apr24-10, 10:54 PM
P: 139
What if I am dealing with degenerate perturbation theory? In the case of the harmonic oscillator, do I need to set up the matrix and find the eigenvalues or can I just take advantage of the lowering and raising operators acting on the eigenstate? Thanks.
kuruman
kuruman is offline
#4
Apr25-10, 05:58 AM
HW Helper
PF Gold
kuruman's Avatar
P: 3,444
What is your Hamiltonian? More to the point, is the ground state degenerate? In any case, "setting up the matrix" involves calculating matrix elements using the raising and lowering operators as I showed you. That you should do, degeneracy or no degeneracy.
Void123
Void123 is offline
#5
Apr27-10, 01:43 AM
P: 139
I have a question though: if the harmonic oscillator is (isotropic), how would two (lowering and raising) operators multiply each other, assuming they are from two different dimensions (e.g. x and y). Would you 'go up or down the ladder' the same way one usually would except plug in the different n-values for x and y, accordingly?
In other words if you had [tex]a_{x} a_{y}[/tex], which are both lowering operators, would you go the typical route of bumping the eigenstate by |n-1>, |n-2>, etc. but plug in [tex]n_{x}[/tex] and [tex]n_{y}[/tex]?
The raising and lowering operators is still a fuzzy area with me.
kuruman
kuruman is offline
#6
Apr27-10, 02:05 PM
HW Helper
PF Gold
kuruman's Avatar
P: 3,444
That is why I asked you to tell me what your Hamiltonian looks like. If you have a two-dimensional isotropic Hamiltonian, you have degeneracies. However, if you write it in Cartesian coordinates, you can separate variables and you can treat each dimension independently. And yes, you get two ladders, one for x and one for y.
Register to reply
Related Discussions
Perturbation theory / harmonic oscillator Advanced Physics Homework 3
Old Quantum Theory and the Linear Harmonic Oscillator Advanced Physics Homework 2
Finding the amplitude an oscillator: Driven harmonic oscillator problem Advanced Physics Homework 1
[SOLVED] Perturbation of the simple harmonic oscillator Advanced Physics Homework 4
A general math theory on the quantum harmonic oscillator? Quantum Physics 3
