Prize Money for 1st Place in 16 Team Bowling League: $1,930
  • Thread starter Thread starter r-soy
    Bowling Money
The problem involves a 16 team bowling league with a total prize pool of $8,000, where the last place team receives $275 and the prize money increases for each successive finishing place. Participants are tasked with determining the amount awarded to the first place team.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • The original poster attempts to use arithmetic sequence formulas to find the prize for the first place team but arrives at an unexpected result. Other participants question the validity of the calculations and the interpretation of the variables involved, particularly the common difference and the initial amount.
Participants are actively engaging with the problem, with some providing alternative calculations and others pointing out errors in reasoning. There is no consensus yet, as different interpretations of the arithmetic sequence are being explored.
There appears to be confusion regarding the definitions of the initial amount and the common difference in the arithmetic sequence, as well as the overall setup of the prize distribution.
r-soy
A 16 team bowling league has $ 8,000 to be awarded as prize money. If the last place
team is awarded $ 275 in prize money and the award increases by the same amount for
each successive finishing place, how much will the first place team receive?
My answer :
a1 -- ? D = 275
an = a1=(n-1 ) d = 275
an = a1 + ( ( 16 - 1 ) d = 8000
a1(15)(275) = 8000
a14125 = 8000
a1 = 1.93
Does that even make sense to you? You are saying that if the last place team won $275, the first place team must have won $ 1.93!
You are told that [itex]a_1= 275[/itex]- "If the last place team is awarded $ 275 in prize money" so 275 is the smallest amount in this arithmetic sequence, not the common difference.
If an arithmetic sequence has initial amount [itex]a_1[/itex] and common difference d, then the nth number is [itex]a_1+ (n-1)d[/itex] and the sum is [itex](a_1+ (n-1)d/2)n[/itex]. You are told that [itex]a_1= 275[/itex], n= 16, and that the sum is 8000 so you can solve for d.
see I write two answer see which one is correct :
An = 2a1 + ( n - 1 ) d
a16 = 275(15) d = 80000
4125d = 80000
d = 8000/4125 = 1.9
Sn = n/2( 2.a1 ( n - 1 ) d
16/2(2(275)(15) d ) = 8000
8(8250d) = 80000
d = 8000/60000 = 0.12
Neither of those is correct! You have solved for d and the question does not ask for d.
13K
  • · Replies 175 ·
28K
