Thread Closed
Maximum velocity of a piston
Share Thread Thread Tools
Apr24-10, 12:06 PM   #1
A piston in an automobile engine is in simple harmonic motion. Its amplitude of oscillation from the equilibrium (centered) position is ±4.73 cm and its mass is 1.733 kg. Find the maximum velocity of the piston when the auto engine is running at the rate of 4380 rev/min.
Answer in units of m/s.
2. Relevant equations
Vmax=Aw
3. The attempt at a solution
I attempted to take the Amplitude (.0437 m) and multiply it by the angular frequency. I first converted it into revolutions per second and then divided 2pi by the answer I got.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Apr24-10, 12:23 PM   #2
Recognitions:
Gold Membership Gold Member
Hello Bearbull,w=2pif.
Apr24-10, 12:26 PM   #3
And f=1/T and T=4380 rev/min= 73 rev/s?
Apr24-10, 12:38 PM   #4
Got it wrong again,
Vmax=(.0437m)(2pi(1/73rev/s))
Apr24-10, 01:31 PM   #5
Recognitions:
f=4380r/min=4380/60 revs/second=73r/s
Apr24-10, 01:36 PM   #6
Quote by Bearbull24.5 View Post
This part is wrong. Remember 1 rev = 2pi.
So you multiply by 2pi, and then 1 min = 60 seconds. So you divide by 60 seconds. I did not get 73 rev/s. I got another number.
Apr24-10, 01:41 PM   #7
Recognitions:
w=2pitimes73
Apr24-10, 02:38 PM   #8
I did 2pi*73 rev/s and then multiplied it by my amplitude (.0437 m). Got it wrong.
Apr24-10, 02:41 PM   #9
Recognitions:
What answer did you get and what should the answer be?
Apr24-10, 02:43 PM   #10
Quote by Dadface View Post
I got 20.043989 and I have no idea what the correct answer is supposed to be. I only have one more chance to get it correct
Apr24-10, 02:51 PM   #11
Recognitions:
so you carried out the following calculation:
2 times 3.142(pi)times73times 0.0473.I picked up my calculator and did it and got an answer close to yours but not the same.Try again and report back here before you submit your answer.
Apr24-10, 02:52 PM   #12
Haha. Had the numbers mixed up. Thanks
Apr24-10, 02:55 PM   #13
Recognitions:
I'm always doing that
Thread Closed
Thread Tools
Similar Threads for: Maximum velocity of a piston
Thread Forum Replies
Velocity of efflux in a piston cylinder arrangement. Classical Physics 8
Velocity Maximum Introductory Physics Homework 19
single piston engine problem - position of piston Introductory Physics Homework 8
Derving piston position and instant velocity Mechanical Engineering 1
How to find the maximum velocity and maximum acceleration? Introductory Physics Homework 5
