L'Hopitals rule and application in limits and limits
The discussion centers on the application of L'Hôpital's Rule in evaluating limits, specifically in the context of functions approaching zero from both sides. Participants clarify that L'Hôpital's Rule can be applied when encountering indeterminate forms like 0/0 or ∞/∞. The limit of the function as x approaches 1/2 is confirmed to be zero from both sides, reinforcing the understanding of even functions and their properties. Additionally, the use of logarithmic functions in the limit calculations is emphasized, particularly in simplifying expressions for derivatives.
  • Understanding of L'Hôpital's Rule for limits
  • Knowledge of logarithmic functions and their properties
  • Familiarity with the concept of even functions
  • Ability to compute derivatives using the product and quotient rules
  • Study the application of L'Hôpital's Rule in various limit scenarios
  • Learn how to simplify logarithmic expressions in calculus
  • Explore the properties of even and odd functions in depth
  • Practice finding derivatives using both product and quotient rules
Students and educators in calculus, particularly those focusing on limits and derivatives, as well as anyone seeking to deepen their understanding of L'Hôpital's Rule and its applications in mathematical analysis.
moocav
http://img227.imageshack.us/img227/9792/hopitalsruleandlimits.png
Ive added a picture of the question. I know that l'hospital's rule is lim x->a f(x)/g(x) = lim x->a f'(x)/g'(x) but I don't understand how to apply it in this situation >< and the other questions I don't understand how to start off and what to get to. If anyone could please help me with ANY of the questions i would be so grateful!
progress so far
a) I don't know how get it from positive and from the negative side using the rule, but I used values and from below 1/2 and it approaches 0 from the positive and from above 1/2 it approaches 0
b) i) I've shown its an even function using x= 1 and x= -1
ii) uses stuff from a) so I don't know how to do it. but i assume it does has a limit.. i don't know an explanation though
iii) wild guess.. limit at -1/2 and 1/2 should be.. 0? but why? (if it does = 0)
c) i) I know how to find the derivative using the product rule but I don't understand why its x > 1/2 and -1/2 < x < 1/2
ii) similar to a) don't know how to do that
iii) don't know
iv) f'(3/4) i subbed in the value to upper derivative from above and i get to log [ (5/4)1/4 / 45/4 ] and I am not sure how to go from there
f'(5/6) = log [ (4/3)1/3 / 34/3 how can i simplify that..?
and i don't know what the second part of the question means
v) don't know
d) any easy way of finding f"(x)? or do i have to find the equ using quotient rule and not sure what the explanation should be
e) same with a), not sure how to calculate from infinity from +side and -side.. sub values?
Your link does not work
Right, the limit will indeed be zero from both sides. To show this explicitly, use the hint they provided.
For [itex]x>\frac{1}{2}[/itex],
[tex]\begin{aligned}\ln\left|x-\frac{1}{2}\right|\ln\left|x+\frac{1}{2}\right| &= \ln\left(x-\frac{1}{2}\right)\ln\left(x+\frac{1}{2}\right) \\ &=\left(\frac{\ln\left(x-\frac{1}{2}\right)}{\frac{1}{x-\frac{1}{2}}}\right)\left(\frac{\ln\left(x-\frac{1}{2}\right)}{x-\frac{1}{2}}\right) \end{aligned}[/tex]
If you simply substitute [itex]x=\frac{1}{2}[/itex] into this expression, you get [itex]\left(\frac{\infty}{\infty}\right)\left(\frac{0}{0}\right)[/itex] and so it is in one of the forms that allows you to use l'hospital's rule.
But that doesn't show its even...it only shows that [itex]f(1)=f(-1)[/itex]...to show its even for all [itex]x[/itex] (except [itex]x=\pm\frac{1}{2}[/itex]), you need to show that [itex]\ln\left|(-x)-\frac{1}{2}\right|\ln\left|(-x)+\frac{1}{2}\right|=\ln\left|x-\frac{1}{2}\right|\ln\left|x+\frac{1}{2}\right|[/itex]. That should be fairly easy because of the absolute values (use the fact that [itex]|-a|=|a|[/itex]).
In part [itex]a[/itex], you should end up with [itex]\lim_{x\to \frac{1}{2}}f(x)=0[/itex]...using the substitution [itex]u=-x[/itex], you can write this as
[tex]\lim_{(-u)\to \frac{1}{2}}f(-u)=\lim_{u\to -\frac{1}{2}}f(-u)=0[/tex]
If [itex]f(x)[/itex] is even, what does that tell you? (keep in mind, that in this limit, [itex]u[/itex] is essentially a dummy variable and can be replaced by [itex]x[/itex], which should make the result easier to see)
  • · Replies 31 ·
