Complex log and Winding Number in Pi_1(S^1)
  • Context: Graduate
  • Thread starter Thread starter Bacle
    Complex Log Winding
The winding number of a loop on S^1, defined as w(f) := [log(f)1 - log(f)0]/i2π, presents challenges due to the discontinuity of the complex logarithm on S^1. Since the complex logarithm cannot be defined continuously in regions that wind around the origin, alternative approaches are necessary to make sense of this definition. Notably, the derivative of log(z) is well-defined on the entire circle, allowing for the definition of w(f) via integration. Additionally, lifting paths on the circle to the Riemann surface for log(z) provides a viable method to address these issues.
  • Understanding of fundamental groups, specifically Pi_1(S^1)
  • Familiarity with complex analysis, particularly the properties of the complex logarithm
  • Knowledge of homotopy theory and homotopy classes
  • Experience with Riemann surfaces and their applications in complex analysis
  • Study the properties of the complex logarithm in relation to simply-connected regions
  • Learn about the fundamental groupoid and its relation to winding numbers
  • Explore the concept of lifting paths on Riemann surfaces
  • Investigate integration techniques for defining winding numbers in complex analysis
Mathematicians, particularly those specializing in algebraic topology, complex analysis, and homotopy theory, will benefit from this discussion. It is also relevant for students seeking to deepen their understanding of winding numbers and their implications in topology.
Bacle
Hi, everyone:
I am confused about the def. of winding number of a loop on S^1
( on elements of Pi_1(S^1,1) ). The winding number is defined by
w(f):= [log(f)1)-log(f)0)]/i2Pi
One of the problems is that log cannot be defined continuously on
S^1, since complex logs can only be define in simply-connected regions that do not wind
around the origin --and S^1 fails both these conditions.
How does this definition then make sense.?
2) Also, in my old class notes, we use log to define a homotopy
between any two functions f,g with the same winding number:
f_t(x)=exp[tlog(f)x+ (1-t)g(x))
In which we seem to assume log is continuous. Just curious:
what would happen if g,f had different winding number.?.
I understand each homotopy class [n] in Pi1(S1) consists of
all paths that loop around n times. ft(x) above is clearly a homotopy between
g(x) and f(x)
I am hoping to understand better why the classes [n] and [m] are only homotopic
for m=n. I am aware that we construct the isomorphism by first using the fact that
the cardinality of Pi1(S1) is the same as that of the fiber
of any point under the standard cover by the reals, and that we show that the map
to the deck transformation group is an isomorphism, but understanding the log issue
will help me get more insights.
Thanks in Advance.
I'm surprised that your book said only that and nothing else.
One way to patch things up is to note that w(f) is by noting:
  • That formula is well-defined for paths in simply-connected regions
  • Such paths generate the fundamental groupoid
  • Writing a path as a sum of generators in two different ways yields the same value for the winding number
Another way is that the derivative of log(z) is well-defined on the entire circle, and you can define w(f) via integration.
Another way is to lift paths on the circle to paths on the Riemann surface for log(z).
  • · Replies 24 ·
