New Reply
Experiment to find specific heat of a liquid
Share Thread
Apr28-10, 12:44 PM   #1
Determine the specific heat of a liquid USING a resistance heater.
Exact problem - Design an experiment complete with instrumentation to determine the specific heats of a liquid using a resistance heater. Discuss how experiment will be conducted, what measurements need to be taken, and how the specific heats will be determined. What are the sources of error in your system? How can you minimize the experimental error? How would you modify this system to determine the specific heat of a solid?
2. Relevant equations
For specific heat - VIt = mcT
3. The attempt at a solution
This is our group project and we will be conducting this experiment.
This was the experiment which was planned was as follows -
Heat some water or some other liquid USING a resistance heater.
Then measure the change in temperature.
Also measure the amount of electrical energy (Welec,in)
Also insulate or take into account the heat loss to the surroundings.
So i wanted to know ways to make this experiment better.
And how to make a liquid resistance heater, which will also allow us to measure the amount of electrical energy.
Any other good suggestions?
Thanks =)
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Jan10-12, 02:02 PM   #2
Thank you for you ask this question, I also need to answer as soon as
Can anyone help us?
Jan11-12, 12:10 PM   #3
You might be better off purchasing an electrical resistance heater. You could do some wiring and put it in series with a digital multimeter to determine the current flow and voltage drop being aware of maximum load on the miltimeter. From that you could determine the power and energy input if you time the heating period. Also for around $15 US you can purchase an electrical device that measures instantaneous volts, amperes, watts, time, phase angle, and cumulative KWHrs. It plugs into the AC wall outlet and the heat source plugs into it.
The temperature will also have to me measured accurately and you'll have to ensure the bath temperature is uniform. If you do any mechanical agitation, it must also be included in your energy input.
Heat losses are a top concern. It must be insulated well. Don't forget about the thermodynamics of the liquid's container.
Jan11-12, 04:03 PM   #4
Dear,
Thanks for your help
May I ask you another question?
What we can do to modify this experiment to make it measures the specific heat of solids too ?
Jan12-12, 05:51 AM   #5
Hint: If you place the solid in the liquid with each at a different known temperature, what happens after sufficient time passes?
New Reply
Tags
heater, liquid, resistance, specific, specific heat
Similar discussions for: Experiment to find specific heat of a liquid
Thread Forum Replies
Specific Heat Capacity of solids liquid or Gas, which is largest? Introductory Physics Homework 7
which liquid have low specific heat capacity Introductory Physics Homework 3
Specific Heat experiment Biology, Chemistry & Other Homework 0
Using specific heat stuff to find amount of heat(Q=mCT) Introductory Physics Homework 2
Experiment for specific latent heat of fusion of ice General Physics 3
