Creating a Strong Straw Bridge: Tips and Guidelines for a Physics Class Project
  • Thread starter Thread starter amwbonfire
    Bridge Project
The discussion revolves around a physics project involving the construction of a bridge made from straws and pins, which must span a 50cm gap and support weights without collapsing. The project emphasizes the importance of design for strength and stability.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss the use of triangular shapes in the design for added strength. There are mentions of the challenges faced with limited materials and the need for effective weight distribution.
Some participants have shared ideas about structural design, particularly the use of triangles and arcs, while others reflect on their experiences with the materials. There is an ongoing exploration of design strategies without a clear consensus on the best approach yet.
Participants are constrained by the requirement to use only 50 straws and are not allowed to include central supports. The project has specific failure conditions related to the bridge's ability to hold weight without collapsing.
amwbonfire
Hi everyone,
I've got to build a bridge from straws and pins for a year 12 physics class. Our bridges will be tested for strength by hanging weights off the bottom of them, and the strongest bridge wins. If the bridge collapses or the masses touch the ground, we fail.
Here's some more info:
- The bridge must cover a 50cm gap
- If the bridge falls onto the ground, collapses completely or the masses touch the ground, we fail
- 50 drinking straws are to be used
- Unlimited amounts of pins (sewing pins, the small ones) are allowed to join the straws together.
- The masses must be hung from the bottom of the bridge
- No central supports are allowed (we cannot have straw pillars holding up the bridge)
Any ideas for the strongest design?
Thanks! :smile:
Use lots and lots of triangles!
Nifty!
Triangles are nifty!
Unfortunately, 50 straws wasn't enough to do much... It broke.
But it was really funny! (Well I thought so...)
:smile: :biggrin: :-p
You should've used a lot of triangles in an arc. That way the weight would be transferred onto the ends of the bridge instead of the center. The trick is finding that perfect arc... :rolleyes:
29K
