Combining Infinite Series: Can I Make These Two Series Start at the Same Point?
The discussion focuses on combining two infinite series into a single expression that starts at the same index. The first series, represented as [m=2 to ∞] ∑m(m-1)amxm-2, is successfully rewritten using the substitution n=m-2, resulting in [n=0 to ∞] ∑(n+2)(n+1)an+2xn. However, the second series, [k=1 to ∞] x∑kakxk-1, presents challenges in aligning the indices. The participants emphasize the need to adjust the starting point of the second series to match the first, highlighting the importance of maintaining the integrity of the terms in the process.
  • Understanding of infinite series and summation notation
  • Familiarity with index manipulation in series
  • Knowledge of polynomial terms and their coefficients
  • Basic algebraic manipulation skills
  • Research techniques for manipulating series indices in summations
  • Explore the concept of generating functions for series
  • Learn about convergence criteria for infinite series
  • Study examples of combining series in mathematical analysis
Students in advanced mathematics, particularly those studying series and sequences, as well as educators seeking to clarify concepts related to infinite series manipulation.
Jamin2112
Rewrite the given expression as a sum whose generic term involves xn
[m=2 to ∞] ∑m(m-1)amxm-2 + [k=1 to ∞] x∑kakxk-1
None in this problem
To make the first part involve only xn, I can use the substitution n=m-2.
But I can't make the second part in terms of xn and [n=0 to ∞], as far as I know.
[k=1 to ∞] x∑kakxk-1 = [k=1 to ∞] ∑kakxk = [n=1 to ∞] ∑nanxn
If I try to take change the start of the sum to n=0, that will effect the xn. See what I'm saying? I want to combine this into one big sum from n=0 to ∞.
So don't do that then. At this stage you have two series, both of which are in terms of xn. The only problem is one starts at n=0 while the other starts at n=1. Can you make them start at the same point?
  • · Replies 17 ·
