What is the connection between topology and convergence in probability?
  • Context: Graduate
  • Thread starter Thread starter wayneckm
    Convergence
The discussion revolves around the relationship between topology and convergence in probability, specifically focusing on the topology generated by a metric related to convergence in probability. Participants explore the implications of topologizing by convergence, the existence of metrics for different types of convergence, and the challenges of analyzing topological spaces without explicit metrics.
  • Some participants seek clarification on the nature of the random variable X in the context of convergence in probability.
  • It is proposed that the distance between random variables X and Y can be defined as E[|X-Y|/(1+|X-Y|)], which aligns convergence in this metric with convergence in probability.
  • There is a suggestion that the term "topologized by convergence in probability" implies the need for a corresponding metric to define the topology.
  • Some participants assert that there is no metric or topology associated with almost sure convergence, raising questions about the implications of this absence.
  • A question is raised regarding the completeness of the metric space and the nature of the resulting topological space if it is not complete, particularly in relation to equivalence classes of Cauchy sequences.
  • Concerns are expressed about the ability to analyze topological spaces characterized by convergence modes when a suitable metric cannot be identified.
  • Participants inquire whether it is possible to discuss open sets under a convergence mode without relying on a metric, suggesting that the notion of convergence is central to defining open sets in such topologies.
Participants express varying opinions on the necessity of metrics for analyzing topologies defined by convergence. While some agree on the challenges posed by the absence of a metric for certain convergence types, others explore the implications of this situation without reaching a consensus.
Limitations include the dependence on specific definitions of convergence and the unresolved nature of the relationship between convergence modes and their corresponding metrics.
wayneckm
Hello all,
Recently I come across the description of "a space topologized by convergence in probability". And I can search that it is the topology generated by a metric defined by [tex]E\left[ \frac{|X|}{1+|X|}\right][/tex].
I can understand how a topology related to a metric. However, whenever we come across the word "topologize by some convergence", does that implicitly mean that we should work out the corresponding metric defined for such convergence and then generate the topology by using this metric?
Lastly, can anyone explain why there is no topology associated with a.s. convergence since I cannot find any reference regarding this? Does this mean there is no well-defined metric for a.s. convergence?
Thanks.
could you explain this a little more. What is X? some random variable?
Yes, take distance between random variables [itex]X[/itex] and [itex]Y[/itex] to be
[tex] E\left[\frac{|X-Y|}{1+|X-Y|}\right][/tex]
So... convergence in this metric is the same as convergence in probability. Then go to the topology defined by the metric. That's what they mean "topologized by convergence in probability". Presumably they wanted to use some topological term, so they needed to say what topology was to be used.
Second: You are correct. There is no metric (and indeed no topology) whose convergence coincides with convergence a.e.
Is this metric space complete? If not then you would get a new topological space where the points are equivalence classes of Cauchy sequences. What would this be like? Would it be a space of random variables?
Thanks for all replies.
So another question comes to my mind is:
Whenever one said a space topologized by some convergence mode, it apparently that one always boils down to struggle and work out the suitable metrics in order to characterize the open set in such topology and so one can continuous analysis with them. However, what if one fails to figure out the corresponding metric, so is it still possible to analyze without the explicit structure of topology endowed with this convergence mode?
Or is there any other way to talk about open set under some convergence mode without relying on metric?
People saying "topologized by some convergence mode" apparently indicate me that they primiarily use the notion of convergence to characterize open set, while metric compatible to such topology can luckily be found in some cases (hence turning such topological space into metric space), so there can be some siutations that we cannot do so and so what to do with them?
Thanks.
wayneckm:
I wonder if this may help:
http://planetmath.org/encyclopedia/TopologyViaConvergingNets.html
It is a little late in the day for my presenting it.
  • · Replies 16 ·
  • · Replies 25 ·
