Thread Closed
Volume flow rate
Share Thread Thread Tools
Apr30-10, 09:02 AM   #1
Volume flow rate
Ok another stupid/smart question,
I got a bath with x m^3 volume. And a water flow rate of a tap is y m/s. I also know pressure and velocity. How can I calculate time to fill up bathtub? I know it's simple but I can not figure it out!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Promising doped zirconia
>> New X-ray method shows how frog embryos could help thwart disease
>> Bringing life into focus
Apr30-10, 10:32 AM   #2
You need to know the volume of water coming in per second, then it is easy. If you know the velocity you don't need to know the pressure. However that is not enough, you can have any volume of water at the same velocity/pressure.
Apr30-10, 01:16 PM   #3
Ok, so let's say the radius of pipe is r. This would give the area of outlet. Multiplying Q by A would give me (m/s) by (m^2), thus giving me volume of water coming out.
Does it make any sense?
Apr30-10, 01:39 PM   #4
Volume flow rate
Exactly, so you have m^3/s. If the bathtub fills up at x cubic meters then it takes x/Av seconds.
Now if it is hot or cold water then you have to account for the room temperature difference and it becomes a differential equation with an exponential coefficient in the solution.
Thread Closed
Thread Tools
Similar Threads for: Volume flow rate
Thread Forum Replies
what volume flow rate will keep the pressures in the two horinontal pipes the same? Introductory Physics Homework 1
Volume flow rate Introductory Physics Homework 1
Volume Flow Rate Introductory Physics Homework 1
Volume Flow Rate, Help??? Introductory Physics Homework 1
measuring volume flow rate Mechanical Engineering 9
