Speed of Point on Rim of 50.0 g Disk with 8.00 cm Diameter
The speed of a point on the rim of a 50.0 g disk with an 8.00 cm diameter, rotating with 0.190 J of kinetic energy, is calculated using the relationship between linear speed and angular speed. The moment of inertia for a solid disk is given by C = 1/2 MR², and the rotational kinetic energy is expressed as Krot = 1/2 Iω². By substituting the moment of inertia into the kinetic energy equation and solving for angular speed (ω), the linear speed (v) is determined using the formula v = rω, yielding a final speed of 3.9 m/s.
  • Understanding of rotational dynamics and kinetic energy
  • Familiarity with the moment of inertia for solid disks
  • Knowledge of angular speed and its relation to linear speed
  • Basic algebra for solving equations
  • Study the derivation of the moment of inertia for various shapes
  • Learn about the conservation of angular momentum
  • Explore applications of rotational motion in real-world scenarios
  • Investigate the effects of mass distribution on rotational dynamics
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors looking to enhance their understanding of rotational motion concepts.
tangibleLime
A thin, 50.0 g disk with a diameter of 8.00 cm rotates about an axis through its center with 0.190 J of kinetic energy. What is the speed of a point on the rim?
[tex]C = \frac{1}{2}MR^2[/tex]
[tex]K_{rot}=\frac{1}{2}I\omega^2[/tex]
Since the formula for kinetic rotational energy is [tex]K_{rot}=\frac{1}{2}I\omega^2[/tex], and the constant for the moment of inertia for a solid disk with the axis of rotation about it's diameter is [tex]C = \frac{1}{2}MR^2[/tex], I substituted the I in the second equation with the first equation, resulting in the following:
[tex]K_{rot}=\frac{1}{2}(\frac{1}{2}MR^2)\omega^2[/tex]
Substituting the values that I was supplied with in the problem statement, I came up with this equation:
[tex]0.190=\frac{1}{2}(\frac{1}{2}(0.05)(0.04)^2)\omega^2[/tex]
Solving for [tex]\omega[/tex], I ended up with [tex]\omega \approx \pm 97.5[/tex], which was determined to be incorrect.
Any help would be extremely appreciated.
It asks for the SPEED of a point on the rim. It does not ask for the angular speed.
I figured it was something like that, so shortly after posting the initial topic, I tried [tex]v=r\omega[/tex] as [tex]v=(0.04)(97.5)[/tex] which results in the correct answer of 3.9. Originally I received an answer that was something like 360 (I must have entered a wrong number or something into the calculator) so I ignored it. Then after you posted and backed up my thoughts, I tried again and got the correct answer. Thanks!
  • · Replies 17 ·
  • · Replies 40 ·
