Electrical Circuit/Electrical Power Problem
  • Thread starter Thread starter lucas101
    Electrical Power
Bob requires a solar-powered system to pump water at a rate of 20 litres per hour, necessitating a power supply of 12V and 1A. The solar cell he intends to use produces a maximum of 1W at 6V. To meet the pump's power requirements, the solution involves connecting two groups of six solar cells in parallel to achieve the necessary amperage, followed by connecting these groups in series to attain the required voltage of 12V. This configuration effectively provides the pump with the correct power supply.
  • Understanding of electrical power calculations using the formula P = I * V
  • Knowledge of series and parallel circuit configurations
  • Familiarity with solar cell specifications and performance metrics
  • Basic principles of electrical circuits and components
  • Research solar cell configurations for optimal power output
  • Learn about the characteristics of series versus parallel circuits
  • Explore power management techniques for solar-powered systems
  • Investigate the efficiency of different solar cell models available on the market
Farmers, renewable energy enthusiasts, electrical engineering students, and anyone interested in designing solar-powered systems for practical applications.
lucas101
Bob, the environmentally friendly farmer, wants to install a solar-powered system to pump water from his dam to the sheep troughs. The pump will run during daylight hours to fill the troughs. Bob has calculated that the right sized pump for the job pumps a maximum of 20 litres per hour. To pump this much water, it must be connected to a power supply that can provide a voltage of 12V and a current of 1A.
Bob wants to use a certain model solar cell - they are going cheap on ebay. This solar cell will produce a maximum of 1W. When producing this much power, the solar cell has a measured voltage of 6V.
Design a simple electrical circuit that Bob can use to connect his solar cells to his pump. Explain your reasoning, include a drawing of this circuit, and show all relevant calculations."
P = I * V where,
P is the power measured in watts, I is the current measured in Amps and V is the voltage difference measured in Volts.
This is the equation we have been told to use.
I calculated the power needed for the pump because this wasn't given and
P = I * V
= 1 * 12
= 12 Watts
At this point I am thinking that I may need 12 of these solar cells in parallel to make up the similar power. But then to check this I calculated the current for the solar cell.
P = I * V
1 = I * 6
1/6 amps = I
Now this makes me think that no I need 6 of these in parallel to make up the amperes to the correct level. But then were does that take me with the voltage.
So I guess this confusion is where I'm stuck.
I am actually a biomedical science major and haven't done physics in a while and this problem is frustrating me because it seems like I'm missing some blindingly obvious detail that would easily help me solve the problem.
Help is greatly appreciated.
Luke
we will connect two cells' groups on series . each group has 6 cells on parallel . each group has 6 volt 1amp . then the two groups connected on series have 12 volt 1 amp .
i hope you will understand .
Thankyou, you have given me that nudge that has helped me solve the question! You are a L - wait for it - egend. You are a legend!
  • · Replies 19 ·
  • · Replies 16 ·
